oil pressure sender dead?
Old Dec 13, 2011 | 02:28 PM
johnson-rod's Avatar
johnson-rod
Originally Posted by Cirrus8
I am curious. Do the failures occur only on engines that are frequently run at high RPM? Have any of you who seldom, if ever, run your engines over 3500 RPM had OPM failure. In short, is this a high RPM problem?
Rarely go over 3500, oil changed according to DIC. It was original to my '98 so it lasted 12 years and 77K miles.
I don't know if it's related but it went south after several battery disconnects while trying to fix something unrelated. I did fix the other problem but then I got to watch my OPS self-distruct.
Old Dec 13, 2011 | 02:33 PM
ndavis296's Avatar
ndavis296
there's a youtube video that shows you how to change it without cutting out the back or removing the intake.
Old Dec 13, 2011 | 03:33 PM
65GGvert's Avatar
65GGvert
Yeah, I tried that on a friend's car, couldn't be done. The socket wouldn't even clear the space between the cowl and the intake. There are extra parts in there that weren't shown on the car in the video.
Old Dec 13, 2011 | 03:49 PM
rhoge's Avatar
rhoge
I tried it on my own 2000 coupe and there are definately extra parts. the local Vette shop did an excellent job replacing it. If I have a reoccurance, I'll consider the relocation from MrBill.
Old Dec 13, 2011 | 06:15 PM
TorchRedRocket's Avatar
TorchRedRocket
Originally Posted by Mr.Bill
In my case I hardly go over 3500 and it happened to me, Alway has clean oil in the motor, I think it just happens.
You guys need to start driving your cars like they were meant to be driven!
Old Dec 13, 2011 | 09:37 PM
mcm95403's Avatar
mcm95403
No kidding! I pass 3500 going to Safeway to pick up milk.
Old Dec 14, 2011 | 11:17 AM
johnson-rod
Well then you're really going to hate this....
I cruise at 1500-1600 for hours on end.
I only bring it up to 3.5k when I merge on the turnpike so I won't develop a ridge where my piston rings stop.
I don't feel the need to flog it like a government mule. If you do it will turn around bite you when you least expect it.
Old Dec 15, 2011 | 08:26 AM
mcm95403's Avatar
mcm95403
The rings stop at the same place every time unless your connecting rods are stretching.
Old Dec 15, 2011 | 08:34 AM
im-vettin-on-it's Avatar
im-vettin-on-it
someone on here sells a kit with everything you need to replace your sensor in a new location. I can't remember who it was but it was around 80. If you try the socket method on you tube, you need to grind down the socket in order for it to fit, or snap on makes a thin walled socket that will work but its expensive. With the kit you just unplug your old one, leave it in place and then hook it up to the new sensor in its new location.
Old Jan 1, 2012 | 09:11 PM
mcm95403's Avatar
mcm95403
Thanks to my buddy Mike letting me use his garage again
I was able to pull the intake off and replace the sender yesterday. Not a bad job and I took the oportunity to clean the filter in the Vararam (MAN was it nasty!) and also to clean the intake of the oil film inside. Time for a catch can I guess.
I also got my front tires rotated side to side and rebalanced and replaced my stock lugs with locks and chrome lug nuts. Looks much better now and easier to clean.
I also passed 80K miles on Wednesday - been a busy guy lately.
Old Jan 2, 2012 | 09:44 AM
jrprich's Avatar
jrprich
I know all about copy and paste, It is a lot eaiser seeing it is all in one file just to e-mail it.
Here is a link to the DIY I used.
Mr.Bill
http://forums.corvetteforum.com/1562145914-post272.html
Mr. B, about what as the cost of all the fittings and hose to relocate the sender?
Old Jan 2, 2012 | 10:34 AM
johnson-rod
I know. It's all in my head. It gives me an excuse to punch it. We all have our demons that must be satisfied.
Old Jan 2, 2012 | 10:55 AM
  #33
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I thought you weren't supposed to rotate tires side to side. Most are directional for our cars, and secondly you take a chance on tearing the steel belts since they are used to turn one way, now they turn the opposite way.
Old Jan 2, 2012 | 11:33 AM
  #34
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I think it was around 45 bucks for all the fittings and another 40 for the sender.
I agree... To rotate side to side you would have to break down the tires off the wheels and switch them around.
Old Jan 2, 2012 | 04:22 PM
  #35
dougbfresh's Avatar
dougbfresh
And retrain the TPMS
Old Jan 2, 2012 | 05:26 PM
  #36
mcm95403's Avatar
mcm95403
Side to side as in removed from the wheel, swapped to the opposite direction and re-installed on the opposite side. So the left front is now the right front, and the right front is now the left front - both are facing the correct direction.
There's no other way to do any kind of rotation on our C5's than that.
For some reason (freeway ramps) my drivers side outer seems to wear faster
