Cargo LED
Old Dec 13, 2011 | 06:30 PM
C4Boi's Avatar
C4Boi
Default Cargo LED
How do I remove the cargo hatch light assembly to swtch from incandesant to LED?
It's a 2002 coupe
Old Dec 13, 2011 | 06:46 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I believe the whole unit pops out by prying a little on the ends.
Mr.Bill
Old Dec 13, 2011 | 08:17 PM
tracks03's Avatar
tracks03
if you're wanting to just switch the bulbs, you can pry off the cover.
if you're replacing the whole assembly, it's easy enough to take the interior panel out by unscrewing the black plastic nuts (the ones that are for the cargo cover and net at the top, the others are down in the compartments), and they should slide up and out of the panel.
Old Dec 13, 2011 | 09:37 PM
M56x-11's Avatar
M56x-11
If you take the back side panel off completely. Then you can just unscrew the light out and replace it.
I just replaced mine, very simple to do.
Old Dec 13, 2011 | 10:12 PM
SFL_driver's Avatar
SFL_driver
Mr.Bill
How I did mine when I replaced my bulbs with LEDs
Old Dec 13, 2011 | 11:07 PM
Choreo's Avatar
Choreo
Same here.
Old Dec 14, 2011 | 12:33 AM
CBZZZC5's Avatar
CBZZZC5
5 minute job
Old Dec 14, 2011 | 12:38 AM
leebay's Avatar
leebay
I also changed mine out this week,the cargo lights pop right out. A simple change over.
Old Dec 14, 2011 | 04:37 AM
C4Boi's Avatar
C4Boi
Thanks, all.
Old Dec 14, 2011 | 08:37 AM
chasboy's Avatar
chasboy
Oldtimer
where do we get the led replacement bulb?
Old Dec 14, 2011 | 08:42 AM
M56x-11's Avatar
M56x-11
I would highly recommend purchasing from Neal from Corvettemods. Here is a sale they are having:
http://forums.corvetteforum.com/c5-g...e-savings.html
Old Dec 14, 2011 | 08:43 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
We have them in red, white, and blue ready to ship
http://www.shop.jwmotoring.com/produ...0&categoryId=4
The full kit is the best value right now
Old Dec 14, 2011 | 09:04 AM
Sinister-one's Avatar
Sinister-one
Hmmm..... now this has me thinking....
Old Dec 14, 2011 | 09:39 AM
M56x-11's Avatar
M56x-11
If your curious. The lighting on the floor is the LED's. The lighting on the seats is the OEM lighting from the Map lights.
LED's are much brighter and easier on your eyes, JMO.
Old Dec 14, 2011 | 03:29 PM
chasboy's Avatar
chasboy
Oldtimer
[QUOTE=M56x-11;1579468354]If your curious. The lighting on the floor is the LED's. The lighting on the seats is the OEM lighting from the Map lights.
REAL nice! I can see a big difference.
I still don't understand how to change the map lights in the mirror..
Old Dec 14, 2011 | 04:17 PM
JW Motorsports
Banned Scam/Spammer
If you have the auto dim mirror it's not so easy. It requires soldering. We provide this service. We can also mod that little shifter/helper led.
If you have the standard mirror it's a simple bulb removal and replace.
Old Dec 14, 2011 | 06:27 PM
chasboy's Avatar
chasboy
Oldtimer
Thanks, but that's one nightmare I will avoid!!
To Cargo LED
Old Dec 18, 2011 | 11:07 AM
tracks03's Avatar
tracks03
If you'd like to take it a step further, add some LED strips to the under the rails in the cargo area.
These are easy to add on to the cargo LED wires. Go get the some small, red quick splices from a parts store, pull the panels out, and clamp the strips to the cargo light wires.
The trick, particularly if you use blue like I did, is getting the tint of the colors to match. I left the strips in place, and removed the bulbs.
Old Dec 18, 2011 | 12:40 PM
M56x-11's Avatar
M56x-11
I LIKE THIS!!!!!!!!!!!!Excellent job!
Old Dec 18, 2011 | 12:55 PM
JW Motorsports
Banned Scam/Spammer
One of my local customers did this with our footwell kit. It's plug n play but you have to route the wires behind the housing.
http://shop.jwmotoring.com/product.s...2&categoryId=4
