Turn signal problem. Driver side front
Old Dec 15, 2011 | 06:46 PM
jiujitsu77's Avatar
jiujitsu77
Default Turn signal problem. Driver side front
My driver side front Turn signal will work sometimes and sometimes it won't. When it doesn't work the rear turn signal still works. Has any one had this problem? If so what can I do to fix it? Please help. My inspection is out.
Old Dec 15, 2011 | 07:02 PM
k0ts's Avatar
k0ts
I would guess there's a poor connection between the bulb and socket.. You might try a new bulb.. or unplug, and re plug.
Old Dec 15, 2011 | 08:18 PM
jiujitsu77's Avatar
jiujitsu77
thats what i plan to do. i hope its not something more than that. thanks for the help
Old Dec 16, 2011 | 08:03 PM
El original's Avatar
El original
Replace the bulb and you will be good to go.
To Turn signal problem. Driver side front
