engine oil leak
Old Dec 24, 2011 | 12:52 PM
newyorknick's Avatar
newyorknick
Default engine oil leak
i notice an oil drip ....mechanic says it is the rear engine oil seal...how much will this cost????
Old Dec 24, 2011 | 12:59 PM
damilleniumboy's Avatar
damilleniumboy
It might be the oil pressure sending unit; they leak through the body. Also, the oil level sensor in the oil pan tends to leak.
Old Dec 24, 2011 | 01:05 PM
sfc rick's Avatar
sfc rick
Also make sure it isn't the front crankshaft seal, which oil gets "blown" back on the oil pan and can appear to be a rear engine leak. LS engines are notorious for wearing out front crankshaft seals and balancers.
Old Dec 24, 2011 | 01:30 PM
C5FORFUN2's Avatar
C5FORFUN2
Doesn't the mechanic know?
Old Dec 24, 2011 | 01:38 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Did this mechanic crawl under the car or just guess? Only way to tell is a close inspection underneath and up close. Even then it can trail from somewhere else ending up on the low spot and look like it came from that area.
Old Dec 24, 2011 | 05:42 PM
newyorknick
Default yo
shop performed an oil change and noticed the issue....they suggested injecting dye to more accurately pinpoint the leak.....and i will do that after my monitoring for a few weeks.
Old Dec 24, 2011 | 07:14 PM
Kind of what I was thinking. And if you feel it is too high, get a second estimate.
Old Dec 25, 2011 | 10:09 AM
mmaynard's Avatar
mmaynard
Default Oil Leak
I had to replace my oil pan gasket last year. 2001 vert.
Old Dec 25, 2011 | 11:40 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Make sure you get it checked by a true mechanic and not just a oil change place.
This fix can be very costly, at the very least the whole torque tube needs to be dropped in order to access the rear main seal - it is not a slam dunk easy job!
It would be prudent for yourself to go under there and check too, keeping looking for the highest point of oil wetness, as stated the oil sending unit can drip down the back of the engine and "APPEAR" to be coming from the rear seal
Get a good high powered light, and you can even get a DIE KIT from the local auto store and do it yourself - it comes with the light too!
Let us know what you find - and if you don't have the jack, jack stands etc., enlist a friend who does and give him some beers for the help!
Let us know what you see and find!
Thanks,Matt
To engine oil leak
