Wheel Spacers
Old Dec 27, 2011 | 08:29 AM
VETSTYL's Avatar
VETSTYL
Default Wheel Spacers
Do wheel spacers impact wheel balance or cause vibration, etc?
Old Dec 27, 2011 | 08:44 AM
sfc rick's Avatar
sfc rick
It certainly could if it's poorly built or not installed properly.
I use only hub centric design which centers the spacer to the axle shaft.
http://www.motorsport-tech.com/wheel_adapters.html
Old Dec 27, 2011 | 05:35 PM
tiojames's Avatar
tiojames
I run DRM's(forum sponsor) 5/8" spacers on the front to clear the big brakes an have had no problems. They have been on for over five years now.
Old Dec 27, 2011 | 05:36 PM
MY03C5Z's Avatar
MY03C5Z
The cheap wheel spacers you can get at part stores probably could cause vibrations. They are the non hubcentric type, just a spacer. I was going to use a pair of them for my rear 16" dr's I was going to run but I didnt feel that it was safe since the wheel didnt mount to the hub anylonger, it was just being centered by the lugs. Looked kinda sketchy to me so I going to go with 17" rear wheels for my dr's instead.
Old Dec 27, 2011 | 07:51 PM
Bigcountry7's Avatar
Bigcountry7
I clicked on the motorsport-tech link above to check on ordering some spacers and I was thoroughly confused with all of the measurements required.
Old Dec 27, 2011 | 07:59 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
It's better to use adapters than spacers. Spacers shorten the length of the OEM studs whereas adapters have their own studs to mount the wheels to.
They are also truer and more hubcentric than spacers.
To Wheel Spacers
