Tire pressure sensors
Old Dec 28, 2011 | 08:47 AM
TOPCATHR's Avatar
TOPCATHR
Default Tire pressure sensors
Does anyone know of a person or company that rebuilds or replaces batteries in the sensors on an exchange basis.
It would be great when replacing tires to bring a set of sensors to the tire shop..................
Old Dec 28, 2011 | 08:57 AM
jrose7004's Avatar
jrose7004
Forum member Corvette Don does it.
Old Dec 28, 2011 | 10:13 AM
Forum member Bakersfield also used to do this - but not sure if he still does or if he is even still on the forum.
Old Dec 28, 2011 | 10:25 AM
robertlthomson's Avatar
robertlthomson
Default TPS sensors
I purchased one off of the internet aution site rebuilt for $45 and it works fantastic. Additionally I found this site that offers them for considerably less than the dealerships.
http://www.alltiresupply.com/p-SB-28006.html
Old Dec 28, 2011 | 05:08 PM
DINO84's Avatar
DINO84
Rockauto.com has them for $69.00
Old Dec 29, 2011 | 03:21 AM
DeeGee's Avatar
DeeGee
I see you have a 98
Here's a DIY thread if you're feeling brave:
http://forums.corvetteforum.com/c5-t...-tutorial.html
Old Dec 29, 2011 | 05:07 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I am assuming you are talking about a pre 01 car.
01-04, the battery is not changeable and they are cheap enough just to replace with new.
97-00 have the expensive TPMS and the battery that can be carved out and replaced.
TireRack also sells the TPMS cheaper, like $65 each or so.
Old Dec 29, 2011 | 10:00 AM
rprinty's Avatar
rprinty
Check you tube for a video tutorial on the 97-00 sensor battery replacement. All that is needed are basic soldering skills and some replacement batteries. I've redone 6 sensors and had one fail after installation. Good think I had a spare.
I think it took about 10-15 minutes per sensor to replace the battery, then I let them sit overnight to let the silicone gasket material cure.
Good luck.
Old Dec 29, 2011 | 02:09 PM
ensteele's Avatar
ensteele
St. Jude Donor '13-'14-'15-'16
I did 4 of these and had good results. Just be slow and deliberate and you should be fine.
To Tire pressure sensors
