Decal/logo question
Old Dec 29, 2011 | 07:16 PM
Tenacfan's Avatar
Tenacfan
Default Decal/logo question
I received the replacement flag/checkered flag inserts for the outside logos, however, they came in an envelope with no instructions. Do I have to remove the factory decals or do the new ones install over them? If I have to remove them any advise on removing them? (I'm thinking I have to remove the factory ones just wanted to double check prior to removing them). As always, thanks for your assistance.
Old Dec 29, 2011 | 07:38 PM
From what I've seen, yes, you do have to remove the stock inserts. Using a hairdryer you should be able to warm up the adhesive enough to get a thin screwdriver under the insert and lift it off.
Old Dec 29, 2011 | 08:49 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Are you talking about the little flags in the C5 emblem? If so Vetteman Jack is correct.
How could you you stick them over the old ones?
Old Dec 29, 2011 | 09:26 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Pics of the new ones to be inserted and we'll know for sure!
Thanks,Matt
Old Dec 29, 2011 | 10:27 PM
jrose7004's Avatar
jrose7004
Definately peel the old ones off. Like Jack said, use a hairdryer to heat the old ones up so they peel off easier.
Old Dec 30, 2011 | 10:52 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I got the American Flag type & put them right over the factory orignals. I cleaned the area w/alcohol & used tweezers to place the new ones...My 2 cents. Good luck.
To Decal/logo question
