Head light issue
Old Jan 1, 2012 | 11:22 PM
tracks03's Avatar
tracks03
Default Head light issue
Hey guys, I need your expertise with an issue. Recently, my right head light assembly would stop from coming up all the way. Before, I could switch the lights on and off a couple of times, and it would work fine. But last night, it wouldn't cooperate.
I replaced the plastic gears with brass/bronze gears last year, so I don't think that's the problem. And I could lift the light the rest of the way, but it wouldn't stay all the way up.
Any ideas, or pointing me in the right direction would be appreciated.
Old Jan 2, 2012 | 10:06 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Does the headlight not raise up all the way at all, or does it raise up then fall back into half position?
My guess would be to check the pivots on the lifting arm first both at the motor and at the headlight subframe.
Old Jan 2, 2012 | 10:35 AM
tracks03's Avatar
tracks03
It's just not coming all the way up,and it might lack an inch or so from the full height.
Before, I could turn off the headlights and let them close, and switch them on and off a few times, and it then it would raise all the way.
I'm thinking I'm hitting a dead spot in the motor or something.
Old Jan 4, 2012 | 08:02 PM
tracks03's Avatar
tracks03
eh, so, no one's got some advice for me? i must be the only lucky one having a problem like this.
Old Jan 4, 2012 | 08:55 PM
Oldvetter's Avatar
Oldvetter
Can you manually raise them the whole way by turning the wheel? If you can, the gears are not the problem.
Old Jan 5, 2012 | 08:29 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree. When you said you can lift it up, does that mean using the **** or just pulling it up?
Old Jan 7, 2012 | 10:06 PM
tracks03's Avatar
tracks03
I was actually pulling up on the headlight assy, not with the manual ****.
It hasn't been all that long ago, I replaced the stock plastic gears with the brass ones.
And the problem seems to be sporadic. The past couple of times they've come all the way up the first time I switch on the lights.
Old Jan 8, 2012 | 08:46 AM
dgrant3830's Avatar
dgrant3830
Its possible to have a dead spot in the motor of course. I'm thinking that the controller is stopping the motor thinking it reached the top of the travel before it gets there due to, too much load on the motor, since there is no limit switch. It is also possible to put the motor gear housing back together with the spacers in the wrong positions. If you did this, the blade thingys whatever they are called, can ride up over the rubber bumper stops and jam things, causing the controller to stop the motor. The only way you'll know is to take it apart again.
Old Jan 8, 2012 | 03:14 PM
Oldvetter's Avatar
Oldvetter
Try winding the light up using the wheel. If it slips, your gears or gear box lid are bad. If not, it is probably the motor.
Did you just "glue" the cover on when replacing the gear; or 1) does your gear box has screws or 2) did you use a brace with screws?
To Head light issue
