Adhesive Mounted Accessories
Old Jan 2, 2012 | 06:39 PM
papafrancisco's Avatar
papafrancisco
Default Adhesive Mounted Accessories
Looking through catalogs, I see a great deal of accessories use adhesive for mounting. To mention a few, chrome rings around the rear side lights, exhuast enhancer plate. chrome add-ons under the hood. etc. My question is how lo0ng does the adhesive last.
Old Jan 2, 2012 | 06:50 PM
LoneStarFRC's Avatar
LoneStarFRC
Like anything else, it just depends on the quality of the adhesives used by the vendor. If it's light-duty category stuff, 3M makes the best and it will last for years. UV and ozone resistant.
Old Jan 2, 2012 | 07:21 PM
doug doo wop's Avatar
doug doo wop
I've had my side fender screens and exhaust plate on for 9 years plus the rear deck spoiler, no problem.
Old Jan 2, 2012 | 07:33 PM
TorchRedRocket's Avatar
TorchRedRocket
Plus, it will also be dependent on your prep work in making sure the mounting service is clean.
Old Jan 2, 2012 | 07:37 PM
LoneStarFRC
Surface-prep is key and should not be overlooked.
Old Jan 2, 2012 | 07:43 PM
Buy quality stuff, do the proper prep work before installing and it should last a long time.
Old Jan 3, 2012 | 03:24 AM
DeeGee's Avatar
DeeGee
With good prep they stay in place for years
My exhaust plate has been on there for about 5 years.
Old Jan 3, 2012 | 08:27 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Use Denatured Alcohol.....available in any paint dept. Has never harmed anything of mine ................
Old Jan 3, 2012 | 09:54 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
Agree that surface prep is key. Have serveral pieces both engine compt & exterior for serveral yrs & no problems to date.
Old Jan 3, 2012 | 09:59 AM
Power Hawk's Avatar
Power Hawk
Again, I have gained much needed knowledge on this forum. Thank you. Santa left me some $$ and I ordered a few things for my Corvette. One of them is an exhaust dress up plate. I was wondering if there were any tricks to installing it. Looks like I have my answer.
Old Jan 3, 2012 | 02:20 PM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
Good luck with your instal of the dress-up plate. Suggest you take time to index mounting location (I used masking tape) dry fitting b-4 instal.
Old Jan 3, 2012 | 05:18 PM
Power Hawk's Avatar
Power Hawk
Will do. Thanks for the advise.
Old Jan 3, 2012 | 05:33 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
also. the key is the prep work done BEFORE the part is mounted. i have an exhaust plate that has been on for many years and shows no sign of weakening or coming loose. the mounting surface is also an important consideration. it must be totally clean and free of any dirt or grease for starters.
To Adhesive Mounted Accessories
