Flat tire damage?
Old Jan 3, 2012 | 10:42 AM
retaf's Avatar
retaf
Default Flat tire damage?
I just picked up a sweet 2002 a few weeks ago and running non-run flats on 18 and 19 inch rims. Car is lowered on stock bolts and am wondering if I should ever have a flat on a front tire would I incur any damage to the car?
Also for this reason I'm considering raising just the front end back to stock height. Is this OK without raising the rear of car or do I need to raise all four back to stock?....and is it really necessary to have front end re-aligned after raising?
Old Jan 3, 2012 | 11:01 AM
bumble-z's Avatar
bumble-z
Of course there is allways a possibity of fender damage (especially at higher speeds) when having a tire go out/flat tire, blow out....Especially if your car is in the lowered/slammed, ride height.
When bringing the front end up to stock height, you should allso bring up the rear to stock height also. (proper rake)
Yes you would need to have the car realigned, once you have all corners in their proper ride height.
Good luck.
Old Jan 3, 2012 | 11:09 AM
cdkcorvette7's Avatar
cdkcorvette7
I doubt it. Maybe if you're doing an HPDE but I don't think so for normal driving. The stock bolts don't really let you slam the car to the ground; it's a relatively minor adjustment.
I very much doubt if you'd like the way your car looks with the front end raised and the rear end lowered... I know I wouldn't.
Probably. I guess you might not absolutely have to but your car will not handle nearly as well and you'll have uneven tire wear.
If it were me I'd just leave it alone... If you're really concerned about it raise the front and the rear back to stock height, not just the front.
Old Jan 3, 2012 | 01:45 PM
retaf's Avatar
retaf
Thanks guys, I think i'll just leave it alone. Just for my info though what's an alignment run for these cars?
Old Jan 3, 2012 | 01:56 PM
Dope's Avatar
Dope
Resident moron
Same as any other car with a 4 wheel alignment, depends on the tire shop. $100 around here at town fair tire.
Dope
Old Jan 3, 2012 | 10:34 PM
Around here, a 4-wheel alignment is about $100 too.
To Flat tire damage?
