Rear side Marker problem
Old Jan 4, 2012 | 09:42 PM
mickey_7106's Avatar
mickey_7106
Default Rear side Marker problem
Looks like the cover fell off. there were no signs of my car being hit so it must have fall out on its own. has this ever happen to anybody? thinking of going with flush markers now. how much modification is needed?
Driver side
Pass Side
Old Jan 4, 2012 | 10:34 PM
Navybluevette's Avatar
Navybluevette
St. Jude Donor '12-'13-'14-'15-'16-'17
Are you sure it wasn't hit? Looks like there is a scrap below and toward the wheel opening. The red lense is glued to the silver housing. The are easy to change and you can get a replacement on flea bay pretty cheap.
Old Jan 4, 2012 | 11:05 PM
ALLEGRO's Avatar
ALLEGRO
OUCH
I would suggest just getting two, replace them both and they will look the same.
They are pretty easy to access by removing the outer tail light and going in from the rear.
Good luck
Old Jan 4, 2012 | 11:48 PM
Sure does look like there is some scrapes below where the light was - might have been nicked and the outside of the light came off.
Old Jan 5, 2012 | 04:26 AM
DeeGee's Avatar
DeeGee
The cover just glues onto the housing. I've never seen that before.
Easy to replace by popping the outer tail light. Just be careful as the nut fixes onto a plastic pillar. Dont over tighten it as it's easy to strip the thread and it wont tighten up properly.
Old Jan 5, 2012 | 07:35 AM
runner140*'s Avatar
runner140*
Thought I saw the same (scrap).
Old Jan 5, 2012 | 02:18 PM
mickey_7106
trust me guys she wasnt hurt lol plus that cover was no where to be found in the area.
so how many of you have the flush markers?
Old Jan 5, 2012 | 06:59 PM
El original's Avatar
El original
Those are not OME markers lights...they are some cheap aftermarkets. That should answer your question why they fell apart. LOL
Old Jan 8, 2012 | 12:43 PM
Navybluevette
Your right that was not OEM.
Old Jan 9, 2012 | 07:59 AM
mickey_7106
actually they were pretty expensive for what they are... yes they are adjure markers with black cherry treatment from bill? at corvette enhancements
To Rear side Marker problem
