oil level c5 zo6
Old Jan 5, 2012 | 01:10 AM
michaelfrench's Avatar
michaelfrench
Default oil level c5 zo6
I bought a spare quart of oil and want to check it tomorrow morning. Check it cold or let it warm up and.check it.... Can't find a straight answer. Depending on how the temp is, how full on the dipstick should have the oil
Old Jan 5, 2012 | 01:34 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Mine is always warm when I check it, I do it while I am filling up. Mine is always around the top mark.
Mr.Bill
Old Jan 5, 2012 | 03:38 AM
DeeGee's Avatar
DeeGee
I was always taught to check it cold with all the oil drained back into the sump. It should read full on the dipstick. The capacity is 6.5 qts including the filter
Old Jan 5, 2012 | 04:09 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
I have checked it cold on all of my vehicles for decades...but my Vette reads at the full line with 7 quarts...maybe I have a 1.5 quart filter?
Old Jan 5, 2012 | 04:12 AM
DeeGee's Avatar
DeeGee
After an oil change I seem to need 7 qts to full 6.5 is the book figure.
Old Jan 5, 2012 | 04:21 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
to my friend across the big Atlantic drink
Old Jan 5, 2012 | 08:50 AM
Oldvetter's Avatar
Oldvetter
There are 2 different dipstick "systems" on a C5. Early years read full (6.5 quarts) at the normal fill point at the top of the hash marks.
Later year C5's read full (6.5 quarts) at the MIDDLE of the hash marks (normally this is the half a quart low mark). This is why some people put in 7 quarts, (which won't hurt the engine).
After an oil change with 6.5 quarts of oil, note where your level is. Oh, you drain 4 ounces more oil if you raise the rear end higher than the front when draining oil. The shop manual says to drain oil with the car level, so this four ounces of "old oil" won't hurt anything. I still raise the rear and drain it all, and I only put in 6.5 quarts of new oil.
Old Jan 7, 2012 | 10:50 PM
TEXHAWK0's Avatar
TEXHAWK0
I normally run my 04 Z06 with the oil a little below the full mark when the engine is cold. I figure that the extra oil that drains down offsets the increase in level when the oil is warm and there is still oil up in the engine, so the level comes out right.
Old Jan 7, 2012 | 11:06 PM
Qwik01's Avatar
Qwik01
I always check mine cold. And keep it just below the full mark
Old Jan 7, 2012 | 11:22 PM
I always check mine cold - that way all the oil is back into the oil pan. If I check it warm, I wait a while until the oil can drain back down to the pan.
Old Jan 7, 2012 | 11:39 PM
jrose7004's Avatar
jrose7004
I have always checked it cold.
Old Jan 7, 2012 | 11:56 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
I always run 7qts.
If you ever track your car or maintain high rpms you want a full oil pan.
If you're running a stock oil pump and just driving normal then you guys are splitting hairs over nothing.
To oil level c5 zo6
