heated seats install options
has anyone put them in any other location or i'm open to any ideas or suggestions.
thanks -have a good day
I just finished my heater install and there is PLENTY OF ROOM for the two switches. You have to off set the centers of the switch just a tad from from the T/C switch, and do a small cut on the corner of the circuit board.
For those unfamiliar with the problem, this is the front of an AH/ride control panel:
This is the back of a modified panel and I wasn't brave enough to cut a section away
I went with the ashtray mount and eventually built a small panel to take them. I tried to be too clever and use a piece of matching two tone leather. As you can see I didn't quite get the line straight so I'd go straight black if I did it again. Luckily it doesn't show from sitting height.
I have a rear fog light and I mounted the switch on the knee panel to the left of the steering wheel. trouble is, the passenger wouldn't be able to get access to his or her switch over there
Bill Curlee fitted a switch to the left of the glove box on the panel down there which might work for the passenger.
I have seen pics of switches down on the side of the seat and it would be easy enough to fit while the seat was out of the car. The disadvantage would be that you wouldn't be able to see which setting you had selected (hi or low) and you'd have to do it by feel.
I'd imagine you could also find a spot on each side of the side of the console with enough clearance behind. The rocker switches are quite slim.
thanks
thanks
