DIC Locked Up! Electrical Problem?
Old Jan 6, 2012 | 11:01 PM
mobman's Avatar
mobman
Default DIC Locked Up! Electrical Problem?
I have a 99 coupe that has a problem that's driving me nuts. My DIC seems to be locked up. I have an air pressure sensor out and that is what stays displayed on the DIC. I try reseting and no luck. Changed out the DICswitch assy but no fix. To dig deeper I open the dash and unplug the DIC switch assy. The maintenance manual (volume 3 page 8-645 says the Instrument panel cluster (IPC) supplies a 5v reference for each switch circuit. I put a multimeter on the gray wire (ground) and any of the 6 wires goingto the switch and I get 12v. Am I doing something wrong? Shouldnt I be getting the 5v reference voltage?
I am also unable to pull any codes.
Old Jan 6, 2012 | 11:15 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Okay I hate to say this but have you tried unhooking the negative battery cable for a while and see if that will unlock it?
It's worth a try, but if all else fails get ahold of Bill Curlee here on the Forum, he is the Electrical guru!
If anyone can get you straightened out he will for sure!
Thanks,Matt
Old Jan 7, 2012 | 11:35 AM
mobman's Avatar
mobman
Thanks,Matt
Taking the neg terminal dosent fix. I will try Bill Curlee,Thanks
Old Aug 21, 2012 | 06:51 PM
paul82146's Avatar
paul82146
Default Dic
My friends 98 has the same problem!!!!
HELP!
Old Aug 22, 2012 | 02:05 AM
Mathew702's Avatar
Mathew702
I also have a 99 coupe and had the same problem. I also tried replacing the buttons and had no luck. The buttons were non-responsive. I ended up replacing the IPC (Instrument Panel Cluster). Sadly enough, it's illegal to buy a IPC and install it because the mileage won't match. You must go to the dealership.
Old Aug 22, 2012 | 08:38 AM
I agree that Bill Curlee might have some good advice for you. Will be following this thread to see what you find out - please post up the results.
Old Aug 22, 2012 | 04:55 PM
Ole Blaster's Avatar
Ole Blaster
love to here the results on this matter,,, I have a 99 FRC,,hope Bill can get you the info you need to resolve this...please keep us posted...
Old Oct 9, 2012 | 06:52 PM
dannyman's Avatar
dannyman
TTT
Interesting!!
You out there Bill?
Dan
Old Oct 9, 2012 | 06:57 PM
KOZ's Avatar
KOZ
You do not have to go the dealer to get a new IPC. usspeedo.com
To DIC Locked Up! Electrical Problem?
