So my car is at the Dealer to fix the Service Column Lock Issue, says I need a Electronic Lock Module replaced, about $300, Is this related to the door locks? Not having an issue with those....Any ideas?
There is no real reason to fork over 3 bills to a dealer who sounds like they don't know what they are doing. Maybe you can print the "faqs" page in its entirety and show it to the Service Manager.
They want to replace the column lock motor. Part is about $300 but expect to pay at least that much in labor. The reality is that with a CLB installed you don't need the lock motor.
Was your column locked with the key in the ignition and the engine started? If the column was not locked, get the car back and purchase and install a CLB. About $50 from Corvettes of Houston plus shipping.
Lots of reading on the column lock problems of the C5. Start here and read the first few pages then go to the end of the thread and back up about a dozen pages and read to the end of the thread. In all likelihood your battery is what started the column lock symptoms....
sound to me like a stealership rip off. your other choice is to tell them that the column lock "replacement" is a recall item and doesn't require any additional modifications, and to just perform the recall work. personally, i would just take the car back, buy the column lock by pass set up from corvettes of houston and either make the correction yourself, or have a qualified non dealership mechanic do the work. if you go the mechanic route, it will give you a good chance to establish a relationship with someone for future work on your car.
If you want a little security with the issue, order a ECL by-pass module from Corvette's of Houston $50. and install it yourself. Here's a the instructions: LS1How To
Just get the CLB and not worry about it again. And I would not let the dealer do any work on the car at this point.
I read all of those posts, great info. My car actually had the first Service Bulletin fixed, not the second. The wheel did not lock, just had the fuel shut at 2 mph. Had the battery replaced about a year ago, but will have it tested to make sure its still in good shape. So after they fix it, can I still install the CLB?
Yeah I told them yesterday not to install the part they wanted to charge me for, just what the recall requires. Will pick up the part from one of the suppliers and install it myself. Looks time consuming but not too difficult.....thanks for all the info.
What year is your car and is it a manual or automatic? I can give you precise instructions once I know that. It is NOT time consuming at all if you are even only slightly mechamical in nature. Should be under an hour worst case and more likely under 30 minutes including a beer break in the middle.
It is a 99, M6. Going to orderthe part the the weekend. And I am only slightly mechnically inclined, but I am sure with help I can get it done right.
Thanks.....
