HOT..110 Octane!
Old Jan 11, 2012 | 05:19 PM
tsbbzm's Avatar
tsbbzm
Default HOT..110 Octane!
Seen this at the pump today, 110 octaneracing gasoline! That's some Hot-Stuff!!!
Pretty Cool...but I'm not sure you could run it in a stock Lt1...
Old Jan 11, 2012 | 05:27 PM
betelgeuse's Avatar
betelgeuse
Nope you can't. It has lead in it and it will ruin your cats.
Sunoco makes a 100 octane unleaded race fuel that some of the stations sell.
It won't help power unless you're tuned for it.
Greg
Old Jan 11, 2012 | 05:34 PM
TriplBlk's Avatar
TriplBlk
Thats pretty sweeett lol
how much was it?
Old Jan 11, 2012 | 05:48 PM
robert miller's Avatar
robert miller
Greg
no good at all unless you have a diff tune you can put in it, but put your race tune in hp and just go back to other.
machz800ps's Avatar
machz800ps
Race gas does not run hotter!!! octane is the resistance to burn, higher the number the hotter the flash point.
Puting race gas in your stock long block will do NOTHING.
Im sure a few will post how they felt the power BUT its all a plasibo effect my friends dont waste your money
Race gas is for high compression engines built for racing
Steve
Old Jan 11, 2012 | 05:51 PM
robert miller
one station has it here but will not let you pump it into your car. have to put it in a 10 gallon gas tank, then into the car away from the station....
Old Jan 11, 2012 | 05:56 PM
TriplBlk's Avatar
TriplBlk
Is it just the tune that takes care of this use? or pumps and stuff have to be changed too?
I plan on getting a dual flash pcm, with maybe and auxillary tank with 5 gal. of race fuel
Old Jan 11, 2012 | 06:16 PM
Silverback51's Avatar
Silverback51
Originally Posted by machz800ps
Race gas does not run hotter!!! octane is the resistance to burn higher the number the hotter the flash point.
Steve
Absolutely correct.
It's a common misconception that octane adds power. It does not.
It allows higher compression, different timing, different cam profiles, etc. which result in higher cylinder pressures. That, and more fuel results in more HP.
Old Jan 11, 2012 | 06:28 PM
RMVette's Avatar
RMVette
I run this in my '70....cost an ARM and a leg but the car loves it. I'm at 11:1 so it handles it quite well. I used to run 100 LL aviation fuel until I found the racing gas.
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Steve
Very true.... if your timing is not adjusted for higher octane then its a waste of money. Higher octane fuel allows you to run more timing because it has "less" of a tendency to pre-detonate.
In a perfect world your spark plug would ignite at the exact same time your piston starts its down stroke. You would make the most power that way.
With lower octane fuel they set the timing so that the piston is already well into its down stroke before firing.
If you set your timing too high with a lower octane fuel you run the risk of the fuel detonating before your piston reaches top dead center (still on the upstroke). That's not good. ... You get engine knock, and could damage your engine for sure. Normally your knock sensor will detect this and pull timing from your engine.
Leaded fuel will kill your cats as said above too.
Toque
Toque
Old Jan 11, 2012 | 06:52 PM
m6 c5's Avatar
m6 c5
Toque
Toque
You could get more power if your engine was pulling timing with just premium.
Old Jan 11, 2012 | 08:40 PM
betelgeuse's Avatar
betelgeuse
Toque
Toque
Totally wrong. In every gas engine I know the spark is before top dead center. Higher octane allows you to adjust it even further before the piston hit TDC . Building more pressure and more power.
Greg
Old Jan 11, 2012 | 08:54 PM
Toque's Avatar
Toque
Greg
I stand corrected... thanks for the heads up. I always thought it was based off top dead center. Cool to know thanks !
Toque
Old Jan 11, 2012 | 09:04 PM
machz800ps's Avatar
machz800ps
Greg
Toque,s explanation is correct. But you are correct that a cylinder is fired just before TDC
Steve
Old Jan 11, 2012 | 11:27 PM
itzza427's Avatar
itzza427
Steve
Yep,us old timers remember looking up all the "tune up specs" when we had to throw in point and plugs around every 10-15 thousand miles to keep it running good!! All the specs would include timing numbers ao X amount of degrees BTDC,,Before Top Dead Center !! For that gas,,ideally you'd be running 11.5-12.5 compression and no cats. As stated higher octane resists going off early in higher compression motors and is a waste in regular fuel motors burning some of it's energy too late!!Would be fun to have a car that COULD use it,,IF you could afford it!!
Old Jan 11, 2012 | 11:47 PM
Have never seen a pump with racing gas around here. No need for it in my stock car.
Old Jan 12, 2012 | 10:05 AM
tsbbzm's Avatar
tsbbzm
The station that has this 110 octane, is real close to the Beach Bend Raceway here in Bowling Green KY.
http://www.beechbend.com/dragstrip.htm
To HOT..110 Octane!
Old Jan 12, 2012 | 10:11 AM
machz800ps's Avatar
machz800ps
Yes sir, My first car was a 68 440 gtx back in 1986 and still remember gaping the points wrong the first time and watching the motor jumping around between the fenders going OH SH$T what did i do
Steve
Old Jan 12, 2012 | 10:49 AM
m6 c5's Avatar
m6 c5
They have it at several pumps around here, only reason I know this is because I have a friend had to run some in his all motor honda that put out something like 300 whp.
Old Jan 12, 2012 | 01:04 PM
had2have-it's Avatar
had2have-it
Steve
The spark happens before tdc, the fuel takes a little time to burn fully and provide pressure, that pressure (combustion) occurs after tdc.
