Question on head lights
Old Jan 12, 2012 | 01:14 PM
HG's Avatar
HG
Default Question on head lights
I have a 03 ZO6 and what can I do to make them brighter. Can you just replace the bulb or the whole unit. Their not very bright at night like me.
Old Jan 12, 2012 | 01:25 PM
DeeGee's Avatar
DeeGee
The short answer is either HIDs or Euro headlights. Replacement bulbs just don't cut it.
HIDs are good but some are not DoT approved and can be mega $$$. Euros are an easy fit and a good compromise.
There are lots of threads that look at the various options.
Old Jan 12, 2012 | 01:27 PM
HG's Avatar
HG
Thanks, I'll do a search and see what I find.
Old Jan 12, 2012 | 01:29 PM
DeeGee's Avatar
DeeGee
I fitted Euros as I needed dip left for UK
Heres the T84 fit:
http://www.pfyc.com/pc/VT1003/VTLIGH...+Corvette.html
Old Jan 12, 2012 | 01:33 PM
HG's Avatar
HG
Heres the T84 fit:
Is this the complete Assembly or just a bulb.
Old Jan 12, 2012 | 01:39 PM
Robert 2000's Avatar
Robert 2000
I put replacement bulbs and its better but I still can not see at night... I have been considering either the whole set from JW for like 500ish not certain of price or a set of pop up lights from radioflyer.
J0KER's Avatar
J0KER
Agreed, HID's or Euros are the way to go...
However, in the interim, I highly recommend changing the bulbs to SilverStar Ultra's... Note: not the plain ol' SilverStars... they suck. I found the new Ultra's to be a tremendous upgrade over stock. The white color of these bulbs also look fantastic!
They are a bit pricey at ~ $50 a set, but so far I've got my money's worth from them until I find the right HID kit.
FYI - the bulbs I bought are part # 9006
Cheers!
Old Jan 12, 2012 | 01:42 PM
DeeGee's Avatar
DeeGee
New faceted lenses plus H4 bulbs that give high and low beam from a single bulb.
You can go low wattage(60/55) or high wattage (135/90)
Old Jan 12, 2012 | 01:45 PM
HG's Avatar
HG
Sound like a spring job, too cold this time of year. It looks like you have to pull the motor fro room to get them out.
Old Jan 12, 2012 | 01:49 PM
DeeGee's Avatar
DeeGee
Its just a straight unbolt and refit of the headlamp modules. You dont touch the motors. You need a new wiring harness which plugs into the low beam circuit. Takes a couple of hours.
Old Jan 12, 2012 | 01:52 PM
HG's Avatar
HG
OK, thanks. Come on Spring
Old Jan 12, 2012 | 02:36 PM
jrose7004's Avatar
jrose7004
As mentioned above Silver Star Ultra's are a choice.
Old Jan 12, 2012 | 02:39 PM
chasboy's Avatar
chasboy
Oldtimer
I tried the Silverstar Ultras and did not find much of a difference-I returned them. I bought a set of HID's from a guy on Ebay and they are great.
Old Jan 12, 2012 | 04:06 PM
El original's Avatar
El original
I think the hid's are fine for a short time and then they burn out, they have a short life span. Am I right?
Old Jan 12, 2012 | 05:42 PM
Silverback51's Avatar
Silverback51
I did not see any significant difference. The light is a little whiter, but that's it.
Old Jan 12, 2012 | 08:17 PM
chasboy's Avatar
chasboy
Oldtimer
Nope, Toque and others have theirs for quite awhile. Contact him and he will give you the low down.
Old Jan 12, 2012 | 09:55 PM
zagger's Avatar
zagger
For best bulb go here http://hirheadlights.com/ , as close to hids as they come. I have tried every bulb out there and none come close to these. Otherwise change over to light canons or similar HID housing. Adding HID kit to regular housing produces much brighter light but it is scattered, not focused and blinding to oncoming traffic as well as illegal.
To Question on head lights
Old Jan 15, 2012 | 01:33 AM
C5FORFUN2's Avatar
C5FORFUN2
Another simple & inexpensive improvement is to put high beam bulbs in the low beam socket. I think the procedure was on here, if not I can look it up for you. I did this on my Silverado and Corvette and was happy with the results. The low beam aim remains the same, just more watts, and I don't get flashed for being to bright by oncoming drivers. Have had them this way for 4 - 5 years now. Also have the 4 high mod that helps when the brights are on.
Old Jan 15, 2012 | 11:08 AM
VETJAZZ's Avatar
VETJAZZ
I've been researching this for several months. I had planned to go the ACA HID route but didn't really want to change the original look of the car/lights.
You can replace the original bulbs with HIR's http://hirheadlights.com/ They're plug and play with a slight modification and the light output is significant. http://shnu.us/HIR%20Trimming%20Stock.htm
Then you can get the HI-4 harness from radioflyer that allows low beams to stay on when you go to high beams.
http://forums.corvetteforum.com/c5-g...just-20-a.html
The light output is amazing, all for under $150 and doable in 30-40 minutes.
Old Jan 15, 2012 | 01:27 PM
corvette c5er's Avatar
corvette c5er
replace the headlights with projector headlight with no cutting or what so ever remove old headlight install new headlight very clear and bright
http://www.amazon.com/gp/product/B00...A1DEWWL73YWC4O
