Traction control
Old Jan 22, 2012 | 12:42 PM
onevettenut's Avatar
onevettenut
Default Traction control
what is the minimum diameter difference from front to rear tire , don't want traction control problems
Thanks guys
Old Jan 22, 2012 | 12:43 PM
GBsC5Vert's Avatar
GBsC5Vert
From: LA/OC border, probably sittin' under the patio, by the pool...smokin' a cigar! SoCal
I think I've read here on the no less than 0.5" or so.
Old Jan 22, 2012 | 01:30 PM
onevettenut
I have a 01... thanks for the info. I will shoot for 1/2 to 1 inch
Old Jan 22, 2012 | 05:52 PM
Thanks for the info. This will help next time I need new tires.
Old Jan 22, 2012 | 07:05 PM
Monkey D. Luffy's Avatar
Monkey D. Luffy
Originally Posted by 8VETTE7
Minimum is rear tires 1/2" larger overall diameter than front tires. Maximum is rear tires 1 1/2" larger overall diameter than front tires. This applies if you have BOTH AH and TC. The earlier cars (1997 to mid 1998 didn't have AH available. In mid 98 through 2000 AH was an optional feature. Look for RPO JL4. Beginning in 2001 AH was a standard ferature on the C5.
so 1.4" would work?
Old Jan 22, 2012 | 08:51 PM
Monkey D. Luffy
Thanks 8vette7
Old Jan 23, 2012 | 04:34 PM
onevettenut
I have a tire in mind to use. The difference from front to rear is .45" Will that work with
the T/C and A/H
Old Jan 23, 2012 | 05:25 PM
onevettenut
I will just have to mount them and measure the real height and determent if it will
do the job
To Traction control
