[Z06] Melted o2 wires
Old Jan 27, 2012 | 02:40 AM
seminoles2005's Avatar
seminoles2005
Default Melted o2 wires
Well my car would throw the o2 sensors on and off and just figured the plug wasnt getting a good connection but lately the check engine light has been staying on.
Had some time to do an oil change and decided to get under the car to look at it and found out one of the oxygen sensor wires fell out of its hanger and melted onto the exhaust.
This sounds like a simple fix by just replacing the o2 sensor but the part that has melted is the actual plug that goes to the sensor and that is attached to the cars wiring harness.
I am currently getting 3 codes, pcm P0128, P0135, P0155, all current.
P0135 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 1
P0155 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
Does this mean both of the sensors arent being read? My car has LG longtubes and no cats. Would the best way to fix this problem by splicing the wires back into the o2 sensor??
Also is the P0128 a stuck thermostat??
Old Jan 28, 2012 | 04:58 AM
seminoles2005
any advice on how i should go about this problem with the melted wires? Is their a place online I can buy a new pigtail that i can splice into the original wiring harness??
Old Jan 28, 2012 | 05:59 AM
JMBLOWNWS6's Avatar
JMBLOWNWS6
lsxtune google it
Old Jan 28, 2012 | 03:30 PM
seminoles2005
Thanks! That helped me a ton.
Now I'm not completely sure if this is the right product, could have sworn my o2 harness plug was grey and not black, not sure if itll make a difference just hope its the same size.
http://www.lsxtune.com/shop/product_...roducts_id/894
To Melted o2 wires
