98 fuel pump
Old Jan 31, 2012 | 06:07 PM
akamam98's Avatar
akamam98
Cruising
Default 98 fuel pump
how many fuel pumps do we have, and is the fuel regulator mounted on the fuel pump? tks.........
Old Jan 31, 2012 | 08:09 PM
akamam98's Avatar
akamam98
Cruising
that helped alot. tks.......
Old Jan 31, 2012 | 10:17 PM
Great info. Thanks for posting this up.
Old Feb 1, 2012 | 02:09 AM
DeeGee's Avatar
DeeGee
To add to 8vette7s info, this is the description for my 02. Your system should be the same:
02 Fuel System Description
Two fuel tanks containing 9 gals each store the fuel supply. An electric fuel pump attaches to the fuel sender assembly inside the left fuel tank. The fuel pump pumps fuel through the fuel feed pipe (6) and an in-line fuel filter (9) to the fuel rail. The rear fuel feed pipe (6) has an integral check valve (4) in order to maintain the fuel system pressure in the feed pipe. The pump provides the fuel at a pressure greater than what is needed by the fuel injectors. The fuel pressure regulator, part of the fuel filter (9), keeps the fuel available to the injectors at a regulated pressure. A fuel return pipe (7) returns the unused fuel to the left fuel tank. The fuel pump also feeds the fuel through a tee (5) with an orifice in the fuel feed rear pipe (6) and through the auxiliary fuel feed rear pipe (2) in order to supply the siphon jet pump inside the right fuel tank. The siphon jet pump transfers the fuel from the right fuel tank to the left fuel tank through the auxiliary fuel return rear pipe (3, 8).:
(1)Fuel Feed Pipe (2)Auxiliary Fuel Feed Rear Pipe (left tank to jet pump) (3)Auxiliary Fuel Return Rear Pipe (jet pump to left tank) (4)Fuel Feed Pipe Check Valve (5)Fuel Feed Pipe Tee with Orifice (6)Fuel Feed Rear Pipe (to fuel filter/fuel pressure regulator and siphon jet pump) (7)Fuel Return Rear Pipe (8)Auxiliary Fuel Return Rear Pipe (jet pump to left tank) (9)Fuel Filter/Fuel Pressure Regulator
To 98 fuel pump
