C5 wheel bearings
Feb 8, 2012 | 10:51 AM
C5 wheel bearings
I recently bought a 2000 C5. Does it have wheel bearings that need to be/or can be packed, or are they sealed?
Feb 8, 2012 | 12:00 PM
Feb 8, 2012 | 01:31 PM
The spindles are sealed. I know this for a fact.
The prices on the spindle assemblies (it's a whole unit including the wheel speed sensor ready to bolt and go) runs around the $260 range for fronts/each.
FYI I think from memory the size torx bit you'll need is T25.
I have the bit at home, if you need me to double check the size and let you know send a PM.
Feb 8, 2012 | 01:38 PM
It's a T55. You need to pop the lower ball joint to get to the bottom bolt.
Feb 8, 2012 | 01:44 PM
Go hit the auction site for timken. Can get them for lot less than $260
Feb 8, 2012 | 01:45 PM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I bought Timken at Auto Zone for $150.......order online you can save 10-20% and pick up in store...also if you join their FREE club you can get an additional $20 off unless it has expired...
Feb 11, 2012 | 10:20 PM
Quote:
Originally Posted by
Scooter70
Thanks for correcting me, I can't believe I said 25.
I had to buy that 55 special, I had a kit that included a 50 & 60.... the project was only hold until I got the one between.
Feb 12, 2012 | 09:11 AM
St. Jude Donor '08-'09
~Joshua
I had the exact same problem. All in all the job was pretty easy.
Feb 12, 2012 | 09:13 AM
Picked up a hub bearing on that popular auction site for under $40 shipped, took my buddy and I about 2 hours because we couldnt find the right torx bit.
Feb 12, 2012 | 12:01 PM
~Joshua
Ha ha. I have one in the toolbox from doing the brakes on my old Silverado. GM must be the only one who uses the T55.
