R compound tires
Old Feb 9, 2012 | 11:21 PM
tb30570's Avatar
tb30570
Default R compound tires
I'm thinking of buying an extra set of wheels and a set of R compound tires. OEWheel has 17"x11" wheels that are pretty cheap:
http://www.oewheelsllc.com/Wheels_3/...Wheel-Silver_2
I assume 315/35R17's should fit on the rear with 17"x11" wheels. Would this size fit on the front too?
I want tires that would work for both autocross and drag racing.
What brand would you recommend? Kumho Ecsta V700, Kumho V700 Victoracer, Nitto NT-01?
How much does it cost to get your tires shaved? Do you need to shave the tires for drag racing or just autocross?
Old Feb 10, 2012 | 12:31 AM
Robert 2000's Avatar
Robert 2000
Bump
I have friends that use the toyo R888 and they use mickey thompson drag radials for the straight line ststuff. Also 11 should be to wide front and cutting it close rear. Hopefully someone else will chime in
Old Feb 10, 2012 | 09:56 PM
tb30570's Avatar
tb30570
I'll add the Toyo R888 to the list.
315/35R17's have a 25.7" OD. The antilock brake probably expect to see front tires about 4% smaller, 24.7". There is no way I can find anything close to 24.7" in the front unless they are really narrow.
How much will it mess up the antilock brakes to have almost the same OD in the front and back?
Old Feb 10, 2012 | 10:36 PM
tb30570's Avatar
tb30570
This guy fit 17x11's with 315/35R17's on the front of an F-Body. I'm surprised they fit.
http://www.ebay.com/itm/17-x11-ZR1-S...item3a70234711
Old Feb 10, 2012 | 10:50 PM
nickolbag's Avatar
nickolbag
17" thinspoke w/ a 275 MT DR and something else up front, not sure on that. Sticky and cheap. Probably lighter than a cheap replica also.
Old Feb 11, 2012 | 07:03 AM
tb30570's Avatar
tb30570
is it a good idea to run DR's in autocross? i've heard the sidewalls can't take it.
Old Feb 11, 2012 | 07:34 AM
nobreaks254's Avatar
nobreaks254
I like my Nitto NT 01's. They are on CCW Classics
Old Feb 11, 2012 | 07:56 AM
AU N EGL's Avatar
AU N EGL
tires for Auto-cross and Drag racing are TWO DIFFERENT tires.
The ones above would be best for Auto-x and OK for drag racing.
DR side walls are not very strong for Auto-X cornering
Good luck
Old Feb 11, 2012 | 08:04 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Good luck
Bad idea to use DR's in Autocross.
Old Feb 11, 2012 | 08:10 AM
Jay_Rich's Avatar
Jay_Rich
I run those same rims in the 9.5 size with a 315 hoozier for the strip (friends spare set). Deffinitly not a recommended size with a 9.5 but it works.
You can most deffinitly run that tire on the rim. Someone here uses those rims on his auto X car front and rear 315s all around. Its a Red Targa car.
Jay
Old Feb 11, 2012 | 08:41 AM
Robert 2000
Jay
Wow I didn't think 315 front and rear would work. They must stick out I assume?
Old Feb 11, 2012 | 09:03 AM
nickolbag's Avatar
nickolbag
oops, missed the auto x part.
Old Feb 11, 2012 | 07:41 PM
tb30570's Avatar
tb30570
why are 19"x12" wheels so much cheaper than 17"x12" and 18"x12"? it doesn't seem to make any sense.
Old Feb 11, 2012 | 08:43 PM
JustinStrife's Avatar
JustinStrife
Probably to tailor towards the C6z crowd?
Old Feb 11, 2012 | 08:54 PM
tb30570's Avatar
tb30570
I assume C6 Z06 wheels will fit on a C5?
front: 18x9.5
rear: 19x12
I'm looking at 335/30-19 Kumho Ecsta V710 for the rear and 275/35-18 Goodyear Eagle RS DOT for the front.
Would that be a pretty good set-up for autocross and a little drag racing?
I've found a few sources for these wheels.
http://www.amazon.com/Factory-Origin.../dp/B004SOAGEE
http://www.oewheelsllc.com/Wheels_3/...-5272-Polished
http://shop.jwmotoring.com/product.s...&categoryId=20
Old Feb 11, 2012 | 09:03 PM
JustinStrife
Will they fit? Sure. However they are not the correct offset so they would stick out past the fenders by quite a bit. Unless you had flared fenders at least.
The only way you are going to get 12" wide wheels to fit the rear of a C5, is by tubbing it, putting flared fenders in the back, or just having it look totally awful...
Old Feb 11, 2012 | 09:35 PM
tb30570's Avatar
tb30570
The tires I'm looking at are slicks, I'd only run them for races. I'd be okay with the tires being outside the fenders just for races.
It sounds like with C6 wheels, they will fit without requiring wheels spacers?
To R compound tires
