Does the ign. key switch light up
As to the light? I'd be for it, wouldn't be too hard to make work.
"The Body Control Module (BCM) contains the theft deterrent system logic. The BCM reads the key code from the ignition cylinder when the ignition is turned to the START position. If the code is correct, the BCM will enable the theft deterrent relay and will send a fuel enable signal to the PCM via the class 2 serial data circuit.
If the BCM receives the wrong code, the BCM will immediately go into tamper mode. The tamper mode will lock-out the vehicle starter and fuel injectors for 3 minutes. The SECURITY indicator will flash while the BCM is in tamper mode."
This is why you can remove the VATS system entirely by wiring in a resistor of appropriate value.
Maybe its a translation thing?
VATS key codes:
The BCM measures the resistance value of the resistance of the pellet and allows the fuel system to operate. If it is within +/-10% the car will start.
To check your key value:
Set your digital volt meter to “ohms mode” and measure the value across the pellet.
The 15 resistor codes are:
Resistance Value (Ohms)
1 0.402 (acceptable range .386-.438)
2 0.523 (acceptable range .502-.564)
3 0.681 (acceptable range .650-.728)
4 0.887 (acceptable range .850-.942)
5 1.130 (acceptable range 1.085-1.195)
6 1.470 (acceptable range 1.411-1.549)
7 1.870 (acceptable range 1.795-1.965)
8 2.370 (acceptable range 2.275-2.485)
9 3.010 (acceptable range 2.890-3.150)
10 3.740 (acceptable range 3.590-3.910)
11 4.750 (acceptable range 4.560-4.960)
12 6.040 (acceptable range 5.798-6.302)
13 7.500 (acceptable range 7.200-7.820)
14 9.530 (acceptable range 9.149-9.931)
15 11.801 (acceptable range 11.320-12.290)
http://www.ebay.com/itm/15-WHTE-60mm...t_20048wt_1397
