Bi-Xenon HID retrofit in ACA style housings
Any way you can post up what Mr. Bill sent you? Or for Mr. Bill, can you post it up here?
Those look great.
Those look great.
Originally Posted by Z-Stallion
Great work! How did you level the low beams?
Received 2,682 Likes
2018 C5 of Year Finalist
I thought about performing a similar retro fit to have HID highs, however I like maintaining my flash to pass option. Something not recommended for HIDs.
The HID bulb never powers off between low and high, just the moving shield you see in one of the top pics I posted.
I'm wondering about the wiring of this. Its still plugs into the low beam plug ? What are u using to trigger the plate to move for the high beam ?
Toque
Toque
So the actual high beam bulb in the headlight housing is not plugged into anything at all.
Hope that makes sense.
The low beam harness on the car plugs into the ballast which turns on the HID bulb. The high beam harness on the car plugs into a female harness connector I made that has both pins of the red wires you see in the projector in my pics. When I select high beams, it puts current through the high beam wires on the car and into the two red wires in the projector that activates a magnet in the projector that moves the shield into 'high beam mode'. When the current is removed, a spring snaps the shield back into 'low beam mode'.
Perfectly... thank you !
I may look into this.... as soon as my wife gets over my last Mod Bill...
Details on the parts $$, Part numbers, and where you got them ?
I already have the ACA setup in my car.
Toque
Maybe you are misunderstanding this retrofit, a bi-xenon projector is a single projector that does high and low beams. I don't even have the actual high beam bulbs in the ACA light plugged in, just 2 trigger wires that lift the cut-off shield in the low beam projector. If my low beams are on, flash to pass works just fine.
Projectors w/wires- $135 +s/h
http://www.theretrofitsource.com/pro...roducts_id=101
D2S Bulbs - $90ish for OEM brand (Philips or Osram), might be cheaper on eBay. Or probably $15-20 for asian brands.
Harness to run from HID ballast wires to D2S bulbs...maybe another $20 or so on eBay.
Here is a video of what the projector looks like switching from low to high beam function.
http://youtu.be/XiTiCmtVAlA
#33
If you already have the ACA and HIDs, then you will need:
This will give me something to work on once my wife calms down from my last mod...
Toque
#36
With my setup you will no longer need the Toshiba high beams.
The automotive aftermarket takes a common size HID capsule and re-bases it to a 9005/9006/h3/h3/etc so they fit all sizes. The issue with this is that the housing is designed for the light optics of a halogen bulb of that size, not HID. The HID bulb has a different focal point and output power, so light out put is affected. This is where people get issues with glare, hot spots, throwing light everywhere, etc. Projectors designed for halogen bulbs tend to have less issues with tossing in re-based bulbs than reflector housings, but is not the best way to get the most amount of light output and least amount of glare.
When OEMs (or their tier 1s) design HID projectors, they design them all around the same standard size bulb...D2S. This is what my projector is designed for, and is the optimum setup for HIDs.
#38
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
The projectors used are actually made for HID (D1S). The manufacturer offered them with halogen bulbs to get the prices down on them. The projector optics were not changed.
For those that don't know these were originally offered with D1S bulbs and Phillips ballasts.
Cool DIY though.
Cool DIY though.
#40
Supporting Vendor
Nice setup.
You need to adjust your passenger side down a little. The Left part of the cutoff from each headlight should line up like so (reference the top):
I'm curious what you had in mind. I might be able to help.
