Rear Deck
Old Feb 25, 2012 | 10:53 PM
Walter Parduhn's Avatar
Walter Parduhn
3rd Gear
Default Rear Deck
I have a 2002 convertible, the self supporting feature of the rear deck lid is not working . Do I have to replace the hinges . Any suggestions or comments would be appreciated.
Old Feb 25, 2012 | 11:20 PM
dblerman's Avatar
dblerman
Sounds like the struts are bad. I think I remember seeing them on GMPartshouse for around $25/ea and calls them lift cylinders. I'm sure others will chime in with a part number.
Old Feb 25, 2012 | 11:22 PM
ALLEGRO's Avatar
ALLEGRO
Local parts store.
AutoZone, Advance O Reilly's
Old Feb 25, 2012 | 11:26 PM
dblerman's Avatar
dblerman
Found the GM PART # 10275941
Old Feb 26, 2012 | 02:27 AM
DeeGee's Avatar
DeeGee
Document ID# 656600
2002 Chevrolet Corvette
________________________________________
Folding Top Stowage Compartment Lid Struts Replace
Removal Procedure
1. Open the folding top stowage compartment.
2. Remove the forward end of the strut from the hinge ball stud.
3. Close the folding top stowage compartment lid.
4. Open the rear stowage compartment lid.
5. Remove the strut from the rear ball stud.
Installation Procedure
1. Open the rear stowage compartment lid.
2. Position the rod end of the strut through the access hole between the quarter panel and the support.
3. Install the strut to the rear ball stud.
4. Close the rear stowage compartment.
5. Open the folding top stowage compartment.
6. Install the rod end of the strut to the front of the hinge.
7. Close the folding top stowage compartment.
Document ID# 656600
Old Feb 26, 2012 | 12:14 PM
Walter Parduhn
3rd Gear
Default Rear deck
Thanks for your help, got the old strut rod off and a new one ordered.
Old Feb 26, 2012 | 03:11 PM
65GGvert's Avatar
65GGvert
There are two, one on each side
Old Mar 11, 2014 | 09:26 PM
tankerpapa's Avatar
tankerpapa
1st Gear
Originally Posted by DeeGee
Document ID# 656600
Removal Procedure
Document ID# 656600
Hi, DeeGee,
How do you remove the old struts? Do you "pry" them off? To install new ones, do you squeeze the struts and the ball struts together until they "pop" in place? If so, is there space for plyers big enough to have leverage to squeeze the two parts together?
Thanks for your help, Tankerpapa ( Rafael)
To Rear Deck
