Shifter Knob
Old Feb 29, 2012 | 09:35 AM
scott3392's Avatar
scott3392
Default Shifter ****
98 c5 6 speed.wanting to change out shifter ****. Before I deface or do it all backwards want to change out my stock shifter **** with round one (old style) with gear display came, off a 2010 vette any pointers on how to do this? Thanks
Old Feb 29, 2012 | 09:39 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
To remove the shift **** you must first remove the shift pattern cap to expose the demon key that holds the shift **** firmly in place. To remove the shift pattern cap I used a thin plastic trim removal tool. You can easily make one from a thin piece of scrap plastic.
To remove the demon key, I used a narrow nose vise grip to prevent contact with the stock leather **** and eliminate the risk of any damage. With the vise grip firmly in place, use the flat side of a metal hammer to keep a steady rythm of tapping of the hammer against the elbow of the vise grip and the demon key will come right out as you continue to pull. Just let the vibration loosen the wedged metal demon key.
If you intend on changing the shift boot as well, be careful not to damage the plastic ring that the boot is attched to. The plastic ring also holds the boot in place in the console. This plastic ring is very fragile and will crack easily. These rings are not sold seperately so if you break it you will have to buy a new boot/ring for around $100 from a Forum vendor, more $ from your local dealer, separate the stock boot from the ring and attach the new boot to the ring.
Here are some links that will be of help:
http://www.vetteessentials.com/instr...t_install.html
http://augerresources.com/instructio...ebrakeboot.htm
http://www.redlinegoods.com/C5install.shtm
Old Feb 29, 2012 | 10:14 AM
Dave68's Avatar
Dave68
Default Here's the "key":
Here's how I've done it, many times:
http://www.conceptualpolymer.com/corvette_install.htm
To Shifter Knob
