Stupid steering wheel removal!!!
Old Feb 29, 2012 | 06:58 PM
rtpassini's Avatar
rtpassini
St. Jude Donor '11-'12
Default Stupid steering wheel removal!!!
AHHHH! im getting freakin pissed
I cant get this thing off. I had a 3 arm gear puller that I grinded down and tried, that broke (wasnt pulling quite right though) then I bought some big J hook threaded bolt things that I cut down and made to fit...those didnt work. So I havent told me cheap *** to get out and buy the proper tool.
Went to napa and could only buy their big kit. OK. whatever. game on.
Came home went for it. I hardly applied any pressure and SNAP. there goes one of hooks snapped off.
Before I ordered the kit they said the j hooks were on back order. The kit supposedly carries a lifetime warranty. So I'll have to call them back tomorrow.
What am i doing wrong? Is there anything else I can try??? I made sure with this kit that I had everything on right, and lined up and perfectly straight. My ghetto rigging worked WAY better than the kit did!!
Old Feb 29, 2012 | 07:11 PM
02z06dave's Avatar
02z06dave
when i did mine, i bought the 18$ wheel puller from advance. i had to grind the heads of the bolts to make it work but it came right off without any problems and it didnt break.
Old Feb 29, 2012 | 07:14 PM
rtpassini's Avatar
rtpassini
advance doesnt have any wheel pullers with j hooks...they said they can get the hooks, but those alone are 20 bucks.
Old Feb 29, 2012 | 07:30 PM
02z06dave's Avatar
02z06dave
i know i grinded the bolts that came with there $18 tool to make something of a j and it worked out great
Old Feb 29, 2012 | 07:31 PM
rtpassini's Avatar
rtpassini
ohhhhh....ill have to give that a go.
Old Feb 29, 2012 | 07:40 PM
02z06dave's Avatar
02z06dave
on the right is the bolt as it came. on the left is with it grinded down all the way around except on one side. i also grinded down the thickness of the head.
heres an overhead shot of what i ended up with
Old Feb 29, 2012 | 08:21 PM
sfc rick's Avatar
sfc rick
I apply pressure to the puller by turning the wrench, then tapping the center puller bolt with a ballpeen hammer. It works all the time on tight and/or seized steering wheels.... well mostly LOL!
Old Feb 29, 2012 | 08:39 PM
rtpassini's Avatar
rtpassini
now i have a new issue,
the "hooks" tore out some the metal where they go into and i dont have much metal to use....im not sure what to do next.
what stupid design
Old Feb 29, 2012 | 08:46 PM
02z06dave's Avatar
02z06dave
what stupid design
that will definitly make the method i used harder if not impossible because the bolt doesn't grab on to alot, if you understand what i mean.
i think its time to get out your hacksaw and cut it off.
Old Feb 29, 2012 | 08:48 PM
rtpassini's Avatar
rtpassini
....can you do that? lol. i have a grinder, dremel, sawzall...lol
Old Feb 29, 2012 | 08:55 PM
02z06dave's Avatar
02z06dave
lol. i have used my dremel to cut many things off of cars. wheel hub, gas tank strap, strut assembly. when all else fails cut it off
Old Feb 29, 2012 | 09:31 PM
rtpassini's Avatar
rtpassini
is there anything underneath I need to worry about? I'll try a few other things before destroying a good wheel.
any other ideas?
Old Feb 29, 2012 | 11:56 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I have a spare wheel for sale if you end up needing one...best of luck...oh, you may have to take it to your dealer...be extra careful around that airbag and always sit sideways.
Old Mar 1, 2012 | 12:01 AM
I just take mine into a dealer and have them remove it. That way if they screw it up, the tab is on them. But good luck getting your steering wheel off.
Old Mar 1, 2012 | 12:07 AM
rtpassini's Avatar
rtpassini
i have a momo coming in the mail....but i appreciate the offer. and i have the airbag completely removed.
the weather around here sucks...and screw dealerships. Ill cut it off before bringing it in. lol
but im going to try tapping some holes and using a standard puller.
Old Mar 1, 2012 | 12:19 AM
damilleniumboy's Avatar
damilleniumboy
Tap it with a ruber mallet from the back side, and attempt to pull it again.
Old Mar 1, 2012 | 12:22 AM
rtpassini's Avatar
rtpassini
One of the first attempts I made involved beating it with a hammer. lol
To Stupid steering wheel removal!!!
Old Mar 1, 2012 | 12:51 AM
marvinseah's Avatar
marvinseah
Had a local shop remove my s/w in order to swap to a momo. They said it was awfully difficult to remove. They ended up making a custom puller and was finally able to remove it. Glad I didn't try to do it myself. Good luck!
Old Mar 1, 2012 | 04:06 AM
fhd's Avatar
fhd
4th Gear
Good luck on that i tried every thing bought the right pulley hammered it heated it..... until the metal gave away now I'm stuck with it there is nothing left to do than pulling the whole wheel assembly.
rtpassini go to a shop this dam thing is stuck.
Old Mar 1, 2012 | 04:19 AM
Choreo's Avatar
Choreo
Common problem. I took mine to the Dealership to get my VE Steering wheel installed for about $100. They broke two Snap-On pullers trying to get it off (which Snap-On replaced).
