I recently purchased a 13,000 mile 1999 Auto Convertible in Oklahoma. On the 300 mile trip home I hit rush hour traffic just North of Ft Worth. It took me about an hour to get thru it. I noticed that for the entire trip thru Oklahoma (and after the traffic subsided) the car ran at a tick over the 190 mark. In the traffic the temps crept up 220 then continued to the 230 degree mark. I didn't expect that. Abut that time the traffic let up and I was able to roll and it stayed at 220 then went back down to the tick over 190.
Is this normal? Has anyone had similar experience in traffic. The car didn't get close to the 255 Hot area but since I am not familiar with the car don't know if this is something I should have the dealer check as I may be paranoid about engine heat. Thx
Its normal, the corvette uses a high pressure radiator cap which allows the normal operating temp to be higher than most cars. In traffic your fans will come on around 230 and will drop the temp back down to 190ish.
Perfectly normal. 230 isn't really the danger zone for these motors - creep up too far above 240 and start worrying, get above 250 and you need to figure out what's wrong with your cooling system.
If you get worried, put your AC on. It will turn on BOTH electric cooling fans on your radiator and you will see your engine temp go down.
About 3 years ago I posted the same question!! Mine jumped to 226 and about freaked out!!
Now, just as a maintenance issues, check to make sure you didn't suck in a walmart bag on the radiator. These cars are "bottom feeders" and will suck up grass trimmings, dirt, trash, small children (joking), etc, etc.
In stop and go traffic, your temps are not uncommon. On the open highway, 190 is about right too.
Mine runs about the same. I bought a low mileage '02 in the summer of '09 and the first thing I did was change all fluids (coolant, brake fluid and oil) just to be safe. I believe age makes a difference on all fluids, some more than others.
I have the same experience but I do notice performance suffers GREATLY in mine once I get to 200 or more. Below that and it is fine.
Your temp readings don't sound out of line for transitioning from highway to stop-and-go traffic. Turning the AC on may turn on the radiator fans but may also drive your engine temp up due to the additional work required to run the compressor. If your radiator is plugged, you could push the engine to overheat temps.
If you ever get into a situation where you're approaching boil over and suspect a radiator problem, turn your heater on the highest temp and fan settings. It will be uncomfortable in the car but you can cool the engine and attempt to drive somewhere to get it fixed. Your heater core is essentially another radiator.
I had an old Caddy at one time and was overheating on my way through Canada. That trick allowed me to drive the 50 miles to get across the border into the USA and to my parent's place. I was able to coordinate repairs from there. Turned out the lower half of the radiator was plugged with sludge.
If you're using the heater trick and you lose heat, shut the engine down. You've lost too much coolant!
The car has no engine-driven fan, and when the coolant temp is below 226 F the electric fans do not run either (with the A/C off). So this means that when sitting in traffic, there is very little cooling air being passed through the radiator, and the temps will start to creep up just from normal idle operations.
When the coolant temp reaches 226 F, the low speed cooling fan will be commanded on. It will be turned off when the coolant goes back down to 219 F. As a backup, if the coolant temp reaches 235 F, the high speed cooling fan will come on and will be turned off when the coolant goes back down to 226 F.
When the A/c is on, the low speed fan is commanded on when the coolant gets to 185 F and vehicle speed is less than 35 MPH.
The above is from the service manual. So your operation looks normal.
Also, from the manual, the system does not consider an over temp situation to have occurred until the temp reaches 256 F.
I just recently changed the coolant in my '01, and when finished, I let the engine idle until it got up to the 226 F range, and bingo the fan came on as described and shut off as described.
To make yourself a little more comfortable with the temps, which are normal, install a V2 or V3 fan control switch from saccitycorvette. Just switch on the fans when your temp gets around the 200 degree mark and it'll keep your temp down while in traffic. They really work! They're inexpensive and incredibly easy to install. Takes about 30 min, tops. The new models even turn off the fans with the ingnition. Your fans still run automatically if your temp goes up.
Get one, they're awesome!
Pete O.
You're temperatures fine. Even last summer when the DFW temperatures were much higher than normal, my engine temperature never got above 230, even after modifying the engine (heads, cam). Just be sure to keep the radiator clean (flush it, flush it good), and change the fluids timely and you should be fine.
Not sure, but I think you could re-program the fans to turn on at a bit lower temperature - but don't do this unless your engine's summertime temperatures are creeping above 230. You'll notice this primarily in stop-and-go go afternoon rush hour traffic.
One of the first things to do is to use compressed air or a garden hose and wash out the AC condenser and radiator. It really makes a difference. Our cars suck up everything.
When i had my "Vet" dyno tuned I had them make changes to the computer and adjusted the fans to come on at a lower temp. Now the car never runs over 200 even in traffic. Also elliminated the skip-shift at that time.
