c5 cold air intake
Old Mar 6, 2012 | 01:46 PM
jetblack99's Avatar
jetblack99
2nd Gear
Default c5 cold air intake
I have a '99 and would like opinions on the best cold air intake system (I was told a Halltech Venom but after doing some research, it looks like that only fits a 2001-2004).
Old Mar 6, 2012 | 02:13 PM
hotwheels57's Avatar
hotwheels57
Is this a poll? You won't get a consensus. Popular choices (Blackwing, dual filter, K&N, VOLANT, AFE, etc) don't necessarily mean "best".
There are two that are generally considered true cold air intakes (CAI). They are VARARAM and CALLAWAY "Honker". You will pay more for those but they work very well. They look oem. Both have lots of users/supporters.
HALLTECH may have something as well, but I'm not familiar with all their offerings.
The rest of the after market may be considered cool air intakes.
Cold air intakes isolate the air intake from hot engine compartment air. The cool air intakes get some cool air from the front fascia openings but mostly ingest hot engine compartment air.
My initial choice was an SLP "Blackwing" but it caused erratic lean codes. I also used a modified ('02-04) oem Z06 intake for quite a while which worked very well. I seriously doubt if either actually made any extra horsepower, but they allowed for louder air intake which is what most owners equate to more horsepower.
I recently installed a CALLAWAY "Honker" and I'm very happy with the performance and appearance. I used a HALLTECH "laminar flow straightener" for the MAF which has eliminated any lean codes so far (@ 5200 ft altitude).
raydawg357's Avatar
raydawg357
Everyone will have different opinions. They will range from Vararam, BBK, BlackWing and K&N to name a few. Many will rant on the Vararam for the most HP increase. Do a little research and go with your gut feeling. I use the BBK for now. I have no complaints.
Old Mar 6, 2012 | 02:17 PM
jrose7004's Avatar
jrose7004
Just get a Blackwing and be done with it.
Old Mar 6, 2012 | 02:24 PM
momo20's Avatar
momo20
Hands down the vararam for a cold air intake.be warned it does take a few hours to install
Old Mar 6, 2012 | 02:28 PM
C5Wolfe's Avatar
C5Wolfe
It actually fits! Yeh, I know, the vara ram makes more upper end power but the blackwing is a very well made intake/air setup.
Old Mar 6, 2012 | 03:43 PM
theheartbeat's Avatar
theheartbeat
Calloway Hoonker is the best option period
Old Mar 6, 2012 | 04:33 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Anyone throw error codes as a result of installing any of these bolt-on aftermaket air intakes?
Old Mar 6, 2012 | 04:34 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Not me and I have had mine on for almost 5 years.
Old Mar 6, 2012 | 05:04 PM
jdub2k5's Avatar
jdub2k5
I went blackwing just incase I get caught in a heavy rain
+ i hear vararams filters are a pita/crappy
Old Mar 6, 2012 | 05:15 PM
Orig Ante M's Avatar
Orig Ante M
I'm sticking with my crappy K&N FIPK and will love it and will call it George. It cost enough.
Old Mar 6, 2012 | 05:19 PM
jdub2k5's Avatar
jdub2k5
OH BTW:
installed my blackwing with 0 knowledge of a corvette within about 30-40 minutes including removing the stock intake setup and installed a cf powerduct
Old Mar 6, 2012 | 05:48 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
QUOTE=momo20;1580202813]Hands down the vararam for a cold air intake.be warned it does take a few hours to install[/QUOTE]
You will notice better performance above around 50 MPH! I had to make changes to my tune because of lean codes, but that just showed me that it was getting more air.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Mar 6, 2012 | 07:41 PM
jrose7004's Avatar
jrose7004
Never.
Old Mar 6, 2012 | 07:55 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
The VRB2 knocked 3 plus 10ths of my 1/4 mile time all by itself. Would buy it all over again!
Old Oct 2, 2014 | 05:43 PM
stonewall221's Avatar
stonewall221
No one has any codes with the vararam? I just put mine in and now i have a code, i dont recall exactly what the code was but it something to the effect of "bank 2 lean"
I can tell this thing has really freed up some power but im slightly annoyed now the mil is on. Its on an '04 Z btw if that makes a difference, install wasnt too bad but its definitely not something i care to do again (for those of you looking to buy one, also install vid on youtube)
Old Oct 2, 2014 | 05:49 PM
wardamncorvette's Avatar
wardamncorvette
St. Jude Donor '14-'15
Do the stock mod.... Buy a new filter.
For 13$ I got a new puralator filter, and zip ties.
Takes about 20 minutes and 13. IMO best mod you can do for the cost
To c5 cold air intake
Old Oct 4, 2014 | 11:57 AM
jackthelad's Avatar
jackthelad
If you go Vararam - which is as others have said a genuine cold air/ram intake, do not drive through standing water. Or you will need a new engine. I went with a Halltech Stinger. A bit more induction noise and maybe a few HP. From the data on the K&N site, they reckon the early cars respond better to more air than the later models - last time I looked they had dyno charts on their site for both early and late C5's.
Old Oct 4, 2014 | 12:05 PM
Supercharged111's Avatar
Supercharged111
I've got the now discontinued Hurricane intake, includes a new fiberglass radiator shroud and is a true cold/ram air intake. The only thing I'm not crazy about is the use of a non-factory shroud. I've had my hands on a Vararam and it seemed kinda cheesy. My vote is for the Calloway Honker that I've never seen in real life. Costs an arm, leg, and a left nut for such a simple thing though so I suspect it's a high quality unit plus you keep your factory shroud. The Hurricane's shroud doesn't seal as well as the factory unit, so I had to get creative there. Probably won't spend the money to change it now though.
Old Oct 4, 2014 | 04:18 PM
TXGS507's Avatar
TXGS507
I love these kind of statements.... Yeah, take this guys word for it...
Personally, I have used VRB2, Calloway Honker, currently Halltech Killer Bee II.... Picked up an additional 6-8 rwhp and 11-12 ftlbs of Tq over the Honker and my Throttle response is much snappier, responsive.... FOR ME, the KBII is the best option PERIOD.
