Stock bose amplifier question
Im sure someone here (or in the audio section) who knows what they are talking about will chime in, but until then.
There is an amplifier on the right (pass) side of the console under the bezel and carpet and I believe the door speakers also have amplifiers integrated into them.
The "subs" in the doors have their own small amplifier (25W RMS?) attached to the speaker mount. The 3.5'' twiddlers, and the ones in the rear are run off the head unit. There's a sound processor thing under the dash, but I don't think it actually amplifies the sound.
Its worth filling out your profile or you will not get information specific to your car. I'll guess that you have a coupe as the vert and the FRC are slightly different.
This is the decode for all the components:
(1) Front Door Speaker Assembly RH
(2) Radio Control
(3) Windshield Antenna
(4) Rear Speaker Assembly RH
(5) Antenna Buffer
(6) Rear Lift Window Antenna Cable
(7) Rear Lift Window Antenna
(8) Remote CD Changer
(9) Rear Speaker Assembly LH
(10) Rear Lift Window Antenna Coaxial Extension Cable
(11) Antenna Module
(12) Front Windshield Antenna Coaxial Cable
(13) Front Door Speaker Assembly LH
(14) Radio Control Coaxial Cable
(15) Bose® Signal Processing Module
There are six speakers in four locations, two amplifiers in the forward speaker locations, and an amplifier incorporated into the Bose signal processor. The processor is behind the kick panel at the drivers knee (called the IP left lower insulator panel).
(2) Radio Control
(5) Antenna Buffer
(11) Antenna Module
