c5 floor jack thread
Old Mar 8, 2012 | 11:11 PM
michaelfrench's Avatar
michaelfrench
Default c5 floor jack thread
so i am lowered on stock bolts and its a pain to jack my car up. sick of borrowing a friends jack so im looking for a cheap alternative.... what kind of jack do you have, where did you get it, and pictures of it
thinking either this:
http://www.harborfreight.com/2-ton-l...ump-68050.html
or this:
http://www.harborfreight.com/3-ton-h...ump-68048.html
opinions? i know one is a lower profile but i think the latter will work too if i start lifting car with a scissor jack. which one is worth it....
Old Mar 8, 2012 | 11:22 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
You need the low profile. This is the one I got. It's not the aluminum one like I believe your first link is to, but I don't plan on packing it around anyway. And this one was less than a hundred bucks.
Don't mess around with scissor jack, it's not worth the hassle when you can get a jack that you don't need to for less than a hundred bucks, or right around there.
Old Mar 8, 2012 | 11:28 PM
RetiredSFC 97
Oh yeah, I have jacked the car up and lifted it up on the four stands you see in the pic with no problem,
Old Mar 8, 2012 | 11:33 PM
michaelfrench
more than enough to slide under it and take a tranny and diff out without problems?
also reading up on the arcan xl35r jack. seems real solid for $100.00
Old Mar 8, 2012 | 11:43 PM
jrose7004's Avatar
jrose7004
Just go over to Harbor Frieght and buy a low profile jack amd be done with it.
Old Mar 8, 2012 | 11:58 PM
I use a Craftsman aluminum low profile jack (very lightweight), but lots of people here use the Harbor Freight jacks and are pleased.
Old Mar 9, 2012 | 12:07 AM
GBsC5Vert's Avatar
GBsC5Vert
From: LA/OC border, probably sittin' under the patio, by the pool...smokin' a cigar! SoCal
I have the HF low profile. I think it's the first one the OP listed. Lowest saddle point on first one is I think 2-5/8", the second one listed is 5" at lowest point! That would not even come close to sliding under my Vett.
I got mine at one of HF "parking lot sales", I think it was on sale for like $79 or so. Have not had any issues at all with it for the year I have used it.
Old Mar 9, 2012 | 12:15 AM
michaelfrench
I know harbor freight is know for their cheap products. The jacks seem to work well?
Old Mar 9, 2012 | 03:58 AM
memmer's Avatar
memmer
I bought mine at HB for $79.It works perfect.Can you imagine the monetary cost if this company made faulty hydraulic jacks.I trust mine completely.
FRED
Old Mar 9, 2012 | 07:23 AM
runner140*'s Avatar
runner140*
This is the best jack I have ever used....also from Harbor Freight and is an aluminum racing jack.
Old Mar 9, 2012 | 12:41 PM
Supercharged111's Avatar
Supercharged111
I got the HF jack myself. Used them for 4 years at the Auto Hobby Shop in Okinawa and never had an issue. They're quick too.
Old Mar 9, 2012 | 01:09 PM
Supercharged111
I had a coupin (think Ron White) for mine, so it was 59.99 instead of the usual 119.99.
Old Mar 9, 2012 | 01:10 PM
RetiredSFC 97
I don't know how much room you need to do that as I never have. But I would think so, yes. I had mine up, I don't know, 2 feet maybe or more. I could get around and crawl around with ease I do know that. I know a 2 ton is probably sufficient but I went with the 2.5 just cuz.
Old Mar 9, 2012 | 01:17 PM
RetiredSFC 97
OK sorry, I did some research and the first one you listed might be a better choice. It has a higher lifting range by almost 4 inches, so disregard my 2 feet comment earlier. The one I have has a range of 20 inches.
It's fine for me but may not be what you're looking for.
Old Mar 9, 2012 | 02:16 PM
Jims2001's Avatar
Jims2001
I have this same jack. Had it for two years now and works great. Lifts the whole side or back of the Vette with ease. Caught it on sale and had a coupon and paid $39.99.
Old Mar 9, 2012 | 02:53 PM
Gideon's_Test's Avatar
Gideon's_Test
Guess that makes several of us..I've had mine for a few years now and am still happy with it.
Old Mar 9, 2012 | 04:29 PM
GCG's Avatar
GCG
The ATD-7325 (same one as the Omega 29023, just under a different badge) is very well regarded here. Amazon was selling it for $248.83, but now it goes for $299.95. You can see it here.
It's been discussed in depth here.
What really separate this one from the pack, besides its extremely low profile, is its length. It allows you to reach the front and rear crossmembers from the front and rear end of the car respectively, in order to raise the whole axle.
To c5 floor jack thread
Old Mar 9, 2012 | 04:53 PM
RetiredSFC 97
Can you get under the front without the help of anything else raising the car up??
Old Mar 10, 2012 | 06:47 AM
SCM_Crash's Avatar
SCM_Crash
I have this one as well. Except it's orange and I found it at Harbor Freight for cheap. I've been using it for over a year with no problems. It's the lowest 2 ton jack I've seen and it's proven itself time after time.
I still use jack stands though. Never rely on the jack only.
This jack can get under the back of the car with plenty of room for a brace protector, but if you want to get under the front, you're still going to need ramps or something. I've tried numerous ways to get that jack under there, and it's simply not long enough to get under without hitting the body panels.
Old Mar 10, 2012 | 07:14 AM
3318C5's Avatar
3318C5
The same for me! I have the more expensive craftman alum jack, but once I bought the one above, I have never looked back. I also got mine for $39.99 with a coupon. I have had it for 4 + years with a ton of use & have lend it to several folks, NO issues ever. Here is the link:
http://www.harborfreight.com/rapid-p...html-7814.html
If you pick up any car mag, you can usually find a coupon to get it for $59.99
