Different thermostat ?
Old Mar 10, 2012 | 12:20 PM
killain's Avatar
killain
Oldtimer
Default Different thermostat ?
Is there any real benefit to running a lower temperature thermostat over the stock unit on a otherwise basically stock C5 ?
Old Mar 10, 2012 | 01:31 PM
Green_Devil's Avatar
Green_Devil
Old Mar 10, 2012 | 01:35 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
In my opinion a lower stat will start to cool the engine sooner, With that said you should also have your fans reprogramed to come on sooner.
Mr.Bill
Old Mar 10, 2012 | 01:41 PM
TorchRedRocket's Avatar
TorchRedRocket
I'm curious about lower temp thermostats as well and if the pros outweigh the cons. If you drive in cold weather, 20-30 degrees ambient temperature, is it stupid to put in a 160 degree thermostat? With a lower temp thermostat, arent you essentially decreasing the life of your water pump as well since it will kick on earlier and run more frequently?
Old Mar 10, 2012 | 01:46 PM
Mr.Bill's Avatar
Mr.Bill
Hmmmm, Hate to tell you, But as soon as you start your car the water pump is working, It is belt driven. If you only drive in 20-30 temps I would leave it alone.
Mr.Bill
Old Mar 10, 2012 | 01:50 PM
TorchRedRocket
I thought the water pump only starts spinning when the thermostat opens and let's the hot coolant out?
Old Mar 10, 2012 | 01:59 PM
Aerovette's Avatar
Aerovette
It always works / spins. Before the thermostat opens, it is circulating water through the block and not the radiator.
Old Mar 10, 2012 | 02:23 PM
TorchRedRocket
Mr.Bill
You learn something new every day. Thanks for the clarification.
RaW Z06's Avatar
RaW Z06
Without having the fan settings reprogramed, the 160 stat isn't going to do you any good.
Running a 160 stat in cooler climates will also cause your car to throw codes for low temp conditions
I suggest you do alot of research before changing your stat. I did and came to the conclusion in my case the factory 187 works well when all other parts of your cooling system are working properly.
Old Mar 10, 2012 | 02:46 PM
Aerovette's Avatar
Aerovette
The lower thermostat simply allows radiator water into the block sooner. Changing only the thermostat will not (necessarily) lower the operating temperature. It could actually make it worse because it does not spend enough time in the radiator to allow the fans to cool it. If it really made a difference for the good, we would just take them out completely (until winter).
Basically "open" is "open" regardless of what temp it is. Once it gets there, it's just opened.The radiator and fans are doing the real work.
Old Mar 10, 2012 | 03:35 PM
killain's Avatar
killain
Oldtimer
Default Cool thremostat ?
I was under the impression that the lower thermostat also causes the EPCM to run richer and leaner after getting a signal from the temperature sensor which would read cooler with the 160 degree thermostat ? maybe not ?
To Different thermostat ?
