wheel ????
Old Mar 10, 2012 | 04:55 PM
1blkc4's Avatar
1blkc4
Default wheel ????
just installed ruff racing 281 19x8.5 rims that were off a z06 mine is a 99 frc . the front caliper clearance is about a finger nail thickness does this seem right ?The wheel spins with no rubbing issues but dam close
Old Mar 10, 2012 | 05:19 PM
I would think that with the stock front rim size on an FRC being 17" in diameter, the 19" rim should have plenty of room unless you have a big brake kit. I guess as long as it spins freely it is OK but that seems like a very small clearance.
Old Mar 10, 2012 | 07:00 PM
1blkc4's Avatar
1blkc4
Default rims
stock brakes z51 package
Old Mar 10, 2012 | 07:43 PM
vetfeva2's Avatar
vetfeva2
Yeap, sounds right. When I had mine on it was that close as well. Never created a problem. Well until I got C6Z06 brakes, then they had to go.
Old Mar 10, 2012 | 09:22 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
The clearance he's worried about is between the caliper and the spokes - not the barrels. Diameter doesn't matter. You can put a 1/8" spacer if you want a safety barrier.
To wheel ????
