[Z06] HELP! Changing wheel studs
Old Mar 16, 2012 | 04:29 PM
Never Late's Avatar
Never Late
Default HELP! Changing wheel studs
I am going to be changing my wheel studs in the rear driver side tomorrow AM. If i take the hub off do i need to take off the differential cover and pull the axles? Or does the hub come off alone? I did this on an LS1 camaro years ago and i had to pull the differential cover off and pull the axles and hubs out all together. Any input is appreciated
Old Mar 16, 2012 | 10:02 PM
bumble-z's Avatar
bumble-z
Hope this helps.
http://forums.corvetteforum.com/c5-t...pics-incl.html
http://forums.corvetteforum.com/auto...placement.html
http://forums.corvetteforum.com/auto...ed-stud-4.html
Good luck.
Old Mar 17, 2012 | 09:15 AM
CHJ In Virginia's Avatar
CHJ In Virginia
No, you do not need to pull the axle and diff side cover. Just remove the 34mm axle nut, break the ball joints loose and remove the hub. The axle might be corroded in the splines so some pursuasion with a 2X4 and ball peen hammer will get it moving.
Old Mar 18, 2012 | 10:32 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
, why I love this forum.
To HELP! Changing wheel studs
