Competition Mode?
Old Mar 17, 2012 | 09:54 PM
bumr's Avatar
bumr
Default Competition Mode?
I just read in another forum, excuse my infidelity, that if you hold down the active handling control button for 5 seconds, you go into competition mode. I must assume he wasn't talking about a model with the expensive handling option otherwise why go through the 5 second hold. Can anyone tell me exactly what this does other than turning off the active handling which doesn't require a 5 second hold? Does it firm up the suspension or...:?
Old Mar 17, 2012 | 10:01 PM
sainthinds's Avatar
sainthinds
I think it basically reduces traction control but still helps you in extreme conditions
Old Mar 17, 2012 | 10:13 PM
dougbfresh's Avatar
dougbfresh
Read the owners manual-it's explained well. Your car has to have the option-does NOTHING to the suspension.
Old Mar 17, 2012 | 10:19 PM
m6 c5's Avatar
m6 c5
Well for starters it depends on what generation your active handling is, the first gen you had to be stopped and I think it takes ten seconds. The second gen system can be done on the fly and that only takes 5 seconds if Im not mistaken.
Anyways they both do the same thing in that they turn off traction control and leave active handling on, that way if you start to spin you wont lose power but if you start to lose it the computer will help save you.
Old Mar 17, 2012 | 10:30 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
And just to clarify, when he says "start to spin" he means spin tires - not spin your car.
Old Mar 17, 2012 | 10:36 PM
m6 c5's Avatar
m6 c5
Yep But if the car does start to spin active handling will start to intervene to keep it in a straight line.
Old Mar 17, 2012 | 10:39 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
As a side note, it's a super BAD idea to disable the Active Handling. It's there to save your butt.
Old Mar 17, 2012 | 10:48 PM
bumr's Avatar
bumr
Thanks guys. so if I understand correctly, pushing and releasing the button turns off active handling and traction control. If I hold the button down for 5 seconds, I turn off traction control while maintaining active handling. That sound right?
Old Mar 17, 2012 | 11:09 PM
rtpassini's Avatar
rtpassini
St. Jude Donor '11-'12
Some cars, like mine don't have it. because I don't have active handling
Old Mar 17, 2012 | 11:16 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Corvettes are so cheap now, not all owners know how to read! They certainly can't spell.
Old Mar 17, 2012 | 11:17 PM
That is correct.
Old Mar 17, 2012 | 11:18 PM
ronssito's Avatar
ronssito
from the manual ...
Competitive Driving Mode
The driver can select the optional handling mode by
pressing the ACTIVE HANDLING button on the
console for more than five seconds, while the vehicle
is stopped with the ignition on. Competitive Driving
mode allows the driver to have full control of the rear
wheels while the Active Handling System helps steer the
vehicle by selective brake application. The instrument
cluster light will not be on. The Traction Control System
will not be operating. Adjust your driving accordingly.
When you press the ACTIVE HANDLING button
again, or turn the ignition to ACC, the Active
Handling and Traction Control Systems will be on.
The TRAC/ACT HNDLG-ON message will be
displayed temporarily in the DIC and a chime
will be heard.
Old Mar 18, 2012 | 12:01 AM
bumr's Avatar
bumr
After a quick review of your history of postings, let me be the first to thank you for providing the forum with the perfect stereotypical archetype for the corvette - porcupine joke.
Old Mar 18, 2012 | 12:34 AM
doje's Avatar
doje
Nahhhh - porcupines have the ****** on the outside.
You keep settin' 'em up and I'll keep on knockin' 'em down.
Old Mar 18, 2012 | 01:04 AM
3musky3's Avatar
3musky3
i agree with bumr!
with comp mode on car will limit power but you have to be real slideways and its not like traction control starts with taking timing out of engine and if you dont lift will take over throttle also. found this out on a very tight left corner when she snapped loose on me.
Old Mar 18, 2012 | 05:07 AM
ksvette74's Avatar
ksvette74
No matter what year it is, it will take 5 seconds. Only diff is weather or not you have to stop first.
Old Mar 18, 2012 | 07:09 AM
65GGvert's Avatar
65GGvert
Looks like they're having another bad spell of whether out there in Kansas.
To Competition Mode?
Old Mar 18, 2012 | 07:20 AM
99 vett babycar's Avatar
99 vett babycar
ever think about the "search" mode? This subject has been beat to death at least a gizzillian times.
Old Mar 18, 2012 | 07:39 AM
billmiller8's Avatar
billmiller8
My yaw sensor went up code 28-TC-C1282HC and I have disabled my tracation control/active handling you have to be sensible about how you drive but remember probably 80% of all cars out there does not even have it, also I think it was the 1st 2yrs of the C5 did not even have TC/AH and for the next couple of years on the C5 it was a optional item. Thank you Chuck.
Old Mar 18, 2012 | 08:04 AM
m6 c5's Avatar
m6 c5
They did not have active handling as an option but all came standard with traction control, and yes in 99 and 2000 active handling was an option.
