One more nagging problem solved today
Old Mar 18, 2012 | 12:57 AM
f6john's Avatar
f6john
Default One more nagging problem solved today
Ever since I bought my FRC the driver side headlight had an annoying "jiggle" when the lights were on and I hit a bump in the road. I thought I knew where the problem was coming from but was able to confirm my suspicions today. This is why I had so much up and down play in the lift mechanism,
Instead of the pin that connects the lift arm to the headlight it had this allen head bolt and nut which was not the right diameter (too small) and allowed about a 1/4 to 3/8 inch vertical slop.
The small nylon bushing that the correct pin slides through was still in the arm and when I inserted the pin it was snug and eliminated all the slop that had existed.
I had originally thought that a thicker bushing had been used by the factory and that the bushing had somehow worn away and fallen out. Instead, I suppose that the pin either came out on its own or a previous owner was in there for some reason and lost the correct pin. The parts in the pics are from a lucky purchase I made last year thinking the parts might come in handy. Of course the bolt and nut are the ones I removed from my car today and I took the used pin and put it in their place.
Old Mar 18, 2012 | 11:46 AM
matthewlfd's Avatar
matthewlfd
I hated the stock push washer design, so I got a set of replacement pins with cotter pins on the end. Same diameter and almost the exact same length for less than a buck each at my local hardware store.
Much easier to swap in there than tightening a nut on a bolt. But glad you got it fixed! I love when there is a simple and easy fix to annoying issues.
Old Mar 18, 2012 | 12:45 PM
Patches's Avatar
Patches
You have stumbled across one of the fixes those of us with HID/BiXenon headlights do to minimize the "jiggle" that is highly magnified by the switch to aftermarket HID headlights. The sharp cutoff created by the HID is painfully obvious as the slop in the stock headligh bucket mounts allows them to vibrate, transmitting that jiggle to the light output beams. The stock halogens are not very sensitive to that slop so most owners aren't even aware of it. You noticed it because the extra slop created by an undersized bolt accentuated the problem even more. I reduced the radial play in those pins in both my HID-equipped C5's after adding HID's. There is also a second stabilizer bar that is added by one of the designers of one set of HID's I have that helps with the problem as well.
Nice work chasing down the cause of your problem.
Old Mar 18, 2012 | 03:11 PM
f6john's Avatar
f6john
I considered that same option once I saw that someone had used an undersized bolt but since I had another stock pin and it tightened everything up so much I used it instead. If the push washer gives me any problem I will chuck the pin in a vise and drill my own hole for a cotter pin.
It may be an optical illusion but the one with the cotter pin looks smaller in diameter than the stock pin. Did the one you used fit really snug with no play?
Old Mar 18, 2012 | 04:03 PM
matthewlfd's Avatar
matthewlfd
Yea, the picture looks like they are different, but it fits through the nylon bushing exactly like the stock one did. I've got an HID projector retrofit, so any slop would be immediately noticable.
Didn't think of drilling holes in the stock pins...oh well. I'm only out a couple bucks.
Old Mar 18, 2012 | 07:13 PM
bigcypress's Avatar
bigcypress
read the title and was expecting ''divorce'' .
Old Mar 18, 2012 | 09:51 PM
f6john's Avatar
f6john
40 years together this year but not up for parole! This was a life sentence
Old Mar 19, 2012 | 12:11 AM
Good job being persistent and finding the cause of the jiggle. Glad you got it fixed.
To One more nagging problem solved today
