[Z06] Fluid Change
Old Mar 18, 2012 | 07:12 PM
halp's Avatar
halp
Default Fluid Change
Time to change my transmission and diff fluid in 02 Z06.
Plan on using
Mobil 1 ATF 98HC69 for tranny
Mobil 1 LS 75W-90 for rear diff
Anyone have experience with these products?
Old Mar 18, 2012 | 07:16 PM
hobbesnmina2001's Avatar
hobbesnmina2001
St. Jude Donor '10-'11-'12,'14
I use Amsoil in mine.
Old Mar 18, 2012 | 07:33 PM
Mickman's Avatar
Mickman
Old Mar 18, 2012 | 07:53 PM
03BLUDEVLz06's Avatar
03BLUDEVLz06
Same here...just about to order my fluids for the upcoming change.
Old Mar 18, 2012 | 09:15 PM
MTPZ06's Avatar
MTPZ06
Sorry OP, no experience with those products. I ran Royal Purple prior to now running Amsoil...I prefer the Amsoil prodcts.
Old Mar 18, 2012 | 09:39 PM
StingrayRebel's Avatar
StingrayRebel
amsoil here as well
Old Mar 18, 2012 | 11:36 PM
kwik ws6's Avatar
kwik ws6
another Amsoil here
Old Mar 19, 2012 | 03:43 AM
NBM LS1 M6's Avatar
NBM LS1 M6
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Pep Boys does all of my fluid changes. When they are busy, I run by Home Depot and get and hire an illegal alien to crawl under the car while I add fluid from above. The parking lot at Home Depot is paved with asphalt, a petroleom related substance. The oil, coolant, tranny fluid, etc., eventually soak into the same, especially in hot weather.
Old Mar 19, 2012 | 05:09 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Plan on using
I've used both of those products in my C-5 coupe and now Z06 for the past 5 years without issues. Both cars were used in HPDEs and autocrossed regularly.
Don't fall for the the hype of the boutique oils, the off-the-shelf Mobil 1 products are more than adequate.
Old Mar 19, 2012 | 09:27 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Amsoil here....
Procedure on my web site if you want to see some tips on replacing the fluids.
www.ToqueZ06.com
Toque
Old Mar 19, 2012 | 09:46 AM
halp's Avatar
halp
Hi:
Thanks for the reply. I assume the LS 75W-90 contains the correct amount of limited slip additive.
I agree about boutique fluids. Like the people who change Mobil 1 oil every 2000 miles.
Old Mar 19, 2012 | 02:16 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Hi:
It may, but I added the OEM recommended LS additive anyways and this is why. From Mobil's product data:
"Mobil 1 Synthetic Gear Lube LS 75W-90 contains special friction modifiers designed for limited slip-type differentials. In most applications, the addition of special LS (limited slip) additives is not required. For axles requiring the highest level of limited-slip performance, OEM specific LS additives can be added to this fluid."
Old Mar 19, 2012 | 04:47 PM
StingrayRebel
i change mine maybe every 500 miles lol... i don't drive my car much at all so once it gets to a dark bronze color i change it or if the oil % gets down to about 80 or so from starting it up and letting it run in the garage to keep the fluids cycled... it usually ends up being 3 times a year so it's not like i'm spending a ton of money... the trans, diff, and coolant i'll do once a year
Old Mar 19, 2012 | 05:25 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
Use the GM red stuff for the tranny. I changed fluids in the rear and tranny using Mobil1. The tranny was a touch smoother on shifts, a benefit from the the synthenic fluid. BUT, the f***ing front seal started leaking 2 days later. Switched back to GM fluid, but too late, it still leaves a drop on the garage floor after driving it.
I say if you have been using the GM fluid for ten years, why change now? But who knows, you could change to a full synthenic fluid and it might not leak. THese cars are getting kind of old. Think about the age and condition of your seals???
YMMV
Best of luck
Old Mar 19, 2012 | 09:39 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
There is a performance downside to adding too much additive. Too much friction additive can result in the diff clutch plates slipping more than designed, thus your limited slip diff becomes less limited slip (more open). In our C5 Z06 the diff is supposed to transmit 75 ft-lb of torque to the tire with grip (as opposed to 0 ft-lb in an open diff). Too much additive can lower that to something less than 75 ft-lb. While most will never notice this on the street, at a road course or drag strip, it can make a difference as the tire with grip won't get as much forward force and the unloaded tire (inside tire in a tight corner) will just spin. Won't hurt the diff to have to much and if it is more important to you to prevent diff chatter (an annoyance) than more might be better. But to maximize performance, you want just enough to prevent diff chatter.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Mar 20, 2012 | 07:53 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Amsoil for me! You would be wise to follow Subdriver's comments. He knows what he's talking about.
Old Mar 20, 2012 | 05:31 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
I'll remember that the next time I'm getting the fastest time in my run group.
To Fluid Change
Old Mar 20, 2012 | 07:58 PM
Zeppelin654's Avatar
Zeppelin654
Subdriver is the man. All amsoil here. And changing from mobile 1 to Amsoil engine oil next change
Old Mar 20, 2012 | 08:45 PM
algZO6's Avatar
algZO6
do you use the limited slip additive in your personal car with the 75-90?
Old Mar 20, 2012 | 08:59 PM
C66 Racing's Avatar
C66 Racing
I did not in my 06 CTS-V which was my daily driver from 06-09 but was a casualty of my move to DC, and I don't in my current daily driver (sad as it is), a 2003 Chevy Trailblazer (which does have the 5.3L V-8 and AWD at least). Neither diff chattered/s.
