engine steaming
Old Mar 19, 2012 | 03:03 PM
DIABL0's Avatar
DIABL0
Default engine steaming
I got a price to get my engine power steamed for 35 bucks. price sounds good but i was wondering if this could harm it in any way? has anyone had the engine washed before?
Old Mar 19, 2012 | 03:29 PM
dougbfresh's Avatar
dougbfresh
Search on it, LOTS of horror stories.
Old Mar 19, 2012 | 03:30 PM
bumble-z's Avatar
bumble-z
DON'T!!!!
Old Mar 19, 2012 | 03:48 PM
hotwheels57's Avatar
hotwheels57
It may cost you ten times $35 in labor alone to fix electrical gremlins after wards.
Old Mar 19, 2012 | 04:13 PM
OneFast1's Avatar
OneFast1
Have you ever washed your engine compartment? If you have you may not run into problems. but for $35 do not expect anyone to spend the time to protect the areas that are vulnerable to high pressure steam. And is it a steam cleaning or a power wash? The temperature difference is quite great.
Old Mar 19, 2012 | 04:50 PM
DIABL0's Avatar
DIABL0
he uses a pressure washer that heats the water up to a steam.
maybe ill just take a wet rag to it . . . are there any products i can use?
Old Mar 19, 2012 | 04:54 PM
Mickeyrx70's Avatar
Mickeyrx70
Simple Green has always worked for me.
Old Mar 19, 2012 | 05:16 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Word of warning, If you are going to use simple green be sure not to use it full strength, It will tarnish the alt, TB and other things, Be sure to dilute it.
Old Mar 19, 2012 | 05:45 PM
hotwheels57
WINDEX or diluted WINDEX is good to use as well. If it's really greasy...shame on you you can use non chlorinated brake cleaner (with caution to paint) to get those areas followed by diluted SIMPLE GREEN or WINDEX. I sometimes use denatured alcohol saturated on a rag. Fix obvious sources of oil leaks or this is all for naught.
Once it's clean, a regular detailing with 303 PROTECTANT will maintain it that way.
Old Mar 19, 2012 | 08:50 PM
JustinStrife's Avatar
JustinStrife
Diluted Simple Green works great. Keeps this engine bay looking great.
To engine steaming
