Please Help
Old Mar 22, 2012 | 11:29 AM
Van02Vette's Avatar
Van02Vette
8th Gear
Default Please Help
I just have bought a 2002 convertible. I drove it over 18 hours. Everything worked fine. Two hours before i arrived I noticed my lights do not go down and I did not have taillights or dash board lights. I replaced the 10 amp fuse and my lights went down. The fuse blew again and keeps on blowing when I replace it and put my lights on. Any ideas to whats going on or where to start? Thanks.
Old Mar 22, 2012 | 11:46 AM
markKlein's Avatar
markKlein
Sounds like a short somewhere. Check the headlight motor connections. Maybe disconnect one motor at a time to see if you can isolate the problem to one side or the other.
Old Mar 22, 2012 | 12:05 PM
Jeff in Den's Avatar
Jeff in Den
I wouldn't keep stuffing fuses in if they keep blowing until you have checked the circuit for the cause of the high current draw/short.
This may help.
Old Mar 22, 2012 | 12:17 PM
Bluefire's Avatar
Bluefire
Are the lights OEM or aftermarket? If they are ACA HID's the fuse should be 20 amp.
Old Mar 22, 2012 | 12:43 PM
Van02Vette's Avatar
Van02Vette
8th Gear
Old Mar 22, 2012 | 12:49 PM
Good luck finding the problem and let us know what the results are.
Old Mar 22, 2012 | 03:47 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
which 10 amp fuse did you replace?
To Please Help
