Wheel Size
Old Mar 23, 2012 | 12:18 PM
bumr's Avatar
bumr
Default Wheel Size
OK, anyone out there care to waste a little time educating a newbie? I see several different combinations of wheel sizes out there, usually one inch larger in the back but sometimes both the same or both 1 inch larger than stock or...
Can someone explain to me the reasoning behind the various combinations? I assume that there are performance issues rather than just aesthetics.
Old Mar 23, 2012 | 04:06 PM
bumr's Avatar
bumr
Appreciate the input 8VETTE7. I guess no one else wanted to waste time on a newbie. BTW, remember I'm new to this, whats AH/TC?
Old Mar 23, 2012 | 04:29 PM
2004c5blackcoupe's Avatar
2004c5blackcoupe
Check this excellent link out:
http://www.toquez06.com/wheels.html
Thanks Toque
Old Mar 23, 2012 | 04:41 PM
65GGvert's Avatar
65GGvert
In a nutshell, the rear tire diameter has to be more than the front tire diameter in order to keep active handling/traction control from sensing a problem that doesn't exist and shut you down. You can use different size wheels and tires, but the total diameter has to be around 1/2 inch to 1 inch greater in the rear. I won't even try to discuss the torque or speedometer variation part of changing. I'll leave that to the guys who have changed sizes from stock.
Old Mar 23, 2012 | 06:58 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Thanks Toque
Stock Z06 rear tire diameter is 0.7" larger then the front tire.
Stock C5 rear tire diameter is 1.0" larger then the front tire.
Notice that I'm talking about "TIRES" above and not RIMS.
You can go with any size "rims" you want. Just be sure to try to keep the rear tire larger by the above values (as best you can).
Try not to venture too far away from the stock diameter in general.
- If you go with a smaller diameter tire (compared to stock) they will look small in the wheel well.
- If you go with a larger diameter tire (compared to stock) they will really fill out the wheel well but you run the risk of the tire hitting the fender liner.
Toque
Old Mar 23, 2012 | 09:51 PM
I am currently running 19/19 on my car and have adjusted the tire size to ensure I keep the 1" stagger in overall diameter front to rear. On my '00, I ran a 19/20 setup and again bought tires that gave me the proper stagger.
To Wheel Size
