Intake help!!
Old Mar 25, 2012 | 10:55 PM
QuicksilverC5_99's Avatar
QuicksilverC5_99
Default Intake help!!
I have a 99 C5 and I'm wanting to run a LS2 intake manifold is it a direct bolt on for my car also will an LS2 granitelli maff work on my car?
Old Mar 26, 2012 | 06:44 AM
hardcore4sure's Avatar
hardcore4sure
You will need different coolant pipes LS6 style, a MAP sensor extension harness, the LS2 fuel rails/injectors, and throttle body and adapter harness. I would also recommend getting the manifold ported before hand otherwise your gains will be minimal over the LS1 and worse than a LS6.
Old Mar 26, 2012 | 10:30 AM
QuicksilverC5_99
Thanks for the advice!
Old Mar 26, 2012 | 11:23 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have read a number of threads on here that the LS2 intake isn't the best unit for the LS1/LS6 motor, As said above you would be better off with the LS6 intake than the LS2.
Mr.Bill
Old Mar 26, 2012 | 11:25 AM
baxsom's Avatar
baxsom
plus the ls6 is a direct bolt on, same throttle body, same wiring, same fuel rails and injectors.
plus you can keep the coolant tubes.
Old Mar 26, 2012 | 11:29 AM
QuicksilverC5_99
Yeah I think I'm just gonna go with the LS6 another question though how hard is it to run a LS7 throttle body or can I even run it?
Old Mar 26, 2012 | 11:33 AM
Mr.Bill's Avatar
Mr.Bill
The LS7 TB mounts different I believe, You would been to get some kind of adaptors.
Old Mar 26, 2012 | 11:34 AM
QuicksilverC5_99
Ok thanks for the help!
Old Mar 26, 2012 | 12:59 PM
robert miller's Avatar
robert miller
Mr.Bill
MR BILL love my ls2 intake on the car...But the ls6 will be chepter to bolt onto a ls1 motor for sure.
Old Mar 26, 2012 | 01:26 PM
corvettebob1's Avatar
corvettebob1
The LS7 TB does not like the electronics of the C5 it will not work and end up costing you $$$$$ to find that out.
Old Mar 26, 2012 | 01:31 PM
QuicksilverC5_99
Ok thanks!
To Intake help!!
