HID lows and fogs install question
Old Mar 26, 2012 | 03:56 PM
rootpooty's Avatar
rootpooty
Default HID lows and fogs install question
Like the title says I purchased both sets from an awesome forum member here. I also purchased the resistor. Any tips on doing the fogs? I have small hands and it seems like they can be accessed by removing the black plastic shroud around the headlights while they are popped up. Should I install the resistor that it came with? I did a search this morning and im aware of some side effects that HIDs can cause and yes im going to upgrade to projector lamps but I had to do something cause I cant drive with candle lit lenses out here in the middle of nowhere. thanks
also it states on the possibility of having to adjust/position the lights after install. have any of you had to do this?
Old Mar 26, 2012 | 04:07 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
First off you have to make sure the bulbs (lows and highs) are seated right, It is a bear, If you have to adjust your lights your bulbs are not in correctly, Again, I say it is a pain to get the bulbs seated correctly, But it can be done.
As for the fogs the best way is to jack up the front of your car and there are 2 access pannels on the bottom jusr under the fog lights, That is the best way to install the fog bulbs.
Mr.Bill
Old Mar 26, 2012 | 05:47 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Alternatively, you can remove the headlight bezel (3 Phillips screws) headlight cover (4 torx 15 screws) and lower the headlight. This should give you plenty of room to manipulate the fog light bulb, housing and ballast.
Old Mar 27, 2012 | 09:43 PM
rootpooty's Avatar
rootpooty
all this wiring looks complicated i might hold off on this
Old Mar 27, 2012 | 09:59 PM
o2bnkc's Avatar
o2bnkc
Go ahead and do it. Easy,peasy. You will surprise yourself how simple it is.
Old Mar 28, 2012 | 12:07 AM
rootpooty's Avatar
rootpooty
ok so i went ahead and installed the fogs. i hooked up the first side it lit up. wow i must say. so when i installed and fired the second one it blew the left side 10a fuse. i checked the connections and i had the positive/positive lined up. so i replaced the 10a fuses with 20a. all is fine now.
Old Mar 28, 2012 | 12:12 AM
jrprich's Avatar
jrprich
Good advice
Old Mar 28, 2012 | 12:13 AM
o2bnkc's Avatar
o2bnkc
Good job! Now you can help the next person who will have the same questions.
Old Mar 28, 2012 | 12:16 AM
rootpooty's Avatar
rootpooty
yes thanks this is exactly what i did i listened to you and it was easy to manuever in there with the bezel and cover off. thanks again
Old Mar 28, 2012 | 12:42 AM
chasboy's Avatar
chasboy
Oldtimer
The worst part of this job is the time spent trying to maneuver around after removing the headlight parts.
To HID lows and fogs install question
