2001 TPMS Tire Sensor Question
Old Mar 27, 2012 | 04:09 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default 2001 TPMS Tire Sensor Question
Hope you guys can help me out with some info. I usually hang out on the C1/C2 and C3 boards.
I need 4 new tires for my 2001 coupe. The two front sensors are non functional. The two rear tire sensors are missing. They were gone when I bought the car.
I still have the original run-flats with 32K miles on them, so it's time for some new shoes.
Tire sensors:
GM sells them for about $80.00 each. = $320. for a set
Dorman sells them for about $40.00 each. = $160. for a set
My tire guy quoted me the price for 4 GM sensors, but not the Dormans, which I can buy off of EBAY.
QUESTION:
Do either of these "brands" of sensors require some type of installation kit? ("O" rings, gaskets, etc.)
If so, does that "kit" come with the sensors, or is it a separate item?
If I buy the Dorman aftermarket sensors, will I need to buy something else?
Any help will be appreciated.
TIA.
Chuck
Old Mar 27, 2012 | 05:33 PM
darkstar.c5's Avatar
darkstar.c5
Chuck,
Tire Rack has them but you have to call.. for about the same price +4/tire for a rebuild kit. also Gene Cully has them. I just changed wheels/tires a month ago and replaced all my sensors....
to answer your question, you'll need the sensors plus a rebuild kit which comes with rings and such...
Old Mar 27, 2012 | 05:42 PM
Chuck Gongloff
Originally Posted by darkstar.c5
Chuck,
Thanks for the info. I sorta thought that you needed some type of gasket kit.
I'm very familiar with Tire Rack. I can give 'em a call.
I'm not familiar with Gene Cully.
Chuck
Old Mar 27, 2012 | 05:45 PM
darkstar.c5
Chuck
gene is an institution on these forums.. very reputable.
||--Genuine GM C5 Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 – sensor – $41.37 each
15234846 – nuts – $4.03 each
Total setup of 4 is $181.60
Note: The sensor comes with the washer and valve stem cap.
Setup includes: 4 sensors, 4 washers/o-rings, 4 caps and 4 nuts.
from thread http://forums.corvetteforum.com/c5-g...house-com.html
Old Mar 27, 2012 | 06:53 PM
Chuck Gongloff
2001-2004 Sensors
Thank you again, Darkstar.
I've bookmarked that thread. I sorta thought I needed an installation kit, and the TPMS sensors I see on EBAY do not specify that they have the necessary "stuff" to put them in.
As I mentioned, when I bought this C5 over 2 years ago with 24K miles, the rear sensors were already GONE, MIA.
I don't get to the C5 section much, thus I was unfamiliar with Gene.
Come over and visit us old guys in C1/C2.
Chuck
To 2001 TPMS Tire Sensor Question
