What Grade Fuel Do You Use?
Old Mar 30, 2012 | 04:33 PM
waxlrose's Avatar
waxlrose
5th Gear
Default What Grade Fuel Do You Use?
Have you noticed a difference between 87 and 91+ octane?
Old Mar 30, 2012 | 04:34 PM
TwinTurboZ51's Avatar
TwinTurboZ51
93 Octane Shell or BP. I wouldnt put 87 in my Vette
Old Mar 30, 2012 | 04:57 PM
Monkey D. Luffy's Avatar
Monkey D. Luffy
Nothing less than 93 Octane
Old Mar 30, 2012 | 05:22 PM
waxlrose's Avatar
waxlrose
5th Gear
Originally Posted by sfc rick
How come when I put cheap gas in my car it doesn't run as well as it did when I put the gas that GM states in that Owners Manual to use?
I thought the Owners Manual was just kidding?
The owners manual says 91 but you can use 87 you just "may" not get as good of acceleration.
Old Mar 30, 2012 | 06:30 PM
Jeff in Den's Avatar
Jeff in Den
....among other things down the road...
If it was an emergency..87 would get you out of trouble, but I'd stick with what your manual says to use.
Ultimate_Respect's Avatar
Ultimate_Respect
I use 87 on both of my corvettes and never have issues.... Although if I am going to run it hard I will get the tank close to empty and fill her up with 93
Old Mar 30, 2012 | 06:36 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Only 93 octane. I have always used the highest octane premium fuel available in every Corvette I have owned, 93 or higher.
Old Mar 30, 2012 | 06:45 PM
jcsperson's Avatar
jcsperson
NC Events Coordinator
93, but my car isn't stock. I'd use 95 or 97 if I could get it.
Old Mar 30, 2012 | 06:47 PM
jrose7004's Avatar
jrose7004
I can only get 91 around here so that's what I use. I wouldn't use 87 or any ethanol either.
Old Mar 30, 2012 | 06:51 PM
red03vette's Avatar
red03vette
highest i can get around here is 94 from chevron, so that is all i use. next grade down is 91.
duce
Old Mar 30, 2012 | 07:15 PM
chasboy's Avatar
chasboy
Oldtimer
93-93% of the time
Old Mar 30, 2012 | 07:18 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
My Car is tuned for 91,,,that is what I run,,,
Old Mar 30, 2012 | 07:37 PM
JerzeyJoe's Avatar
JerzeyJoe
One time I filled up with 87 by mistake. Out of habit with my pick up, I told the guy, "fill it with regular". Vette was a little rough when stopped, but otherwise I didn't notice any difference. I don't drive my Vette hard.
Old Mar 30, 2012 | 07:53 PM
Ultimate_Respect
So your corvette ran rough when you were at idle on 87? Maybe the fuel had junk in it. There is not that much difference between 87 and 93..
You will get better burn at higher RPMs with 93... But the corvette can take 87 with no problems.. If your motor has high compression than I would say you need 92 or 93. BUT with all stock motors you really reap no real benefits and are just waisting your money..
Old Mar 30, 2012 | 08:14 PM
J Z06's Avatar
J Z06
From Day one I've used nothing but 93 minimum. I will not use anything less, especially with 11:1 compression and a supercharger.
Old Mar 30, 2012 | 09:23 PM
C5Ryan's Avatar
C5Ryan
93 for day to day use. Throw in a couple gallons of 100 when I spray the car.
Old Mar 30, 2012 | 09:34 PM
GoldenFlame's Avatar
GoldenFlame
Sunoco 93, nothing Higher and absolutely nothing lower
To What Grade Fuel Do You Use?
Old Mar 30, 2012 | 10:49 PM
All I've seen around here is 91 octane and that is what I use. But, in a pinch I'd use 89 octane.
Old Mar 30, 2012 | 11:16 PM
Qcksilverc5's Avatar
Qcksilverc5
Shell Premium 93.
Old Mar 30, 2012 | 11:24 PM
LoneStarFRC's Avatar
LoneStarFRC
I use only 93 octane gasoline until I can find the algae that Dear Leader wants me to use. I would also consider solar, but only if I can get a .gov loan.
