throwin codes
Old Apr 1, 2012 | 12:36 AM
darkstar.c5's Avatar
darkstar.c5
Default throwin codes
i just noticed these new codes, all History.
60-IPC - Instrument Panel Cluster >> U1160 Loss of Communications with LDCM
A1-RDCM - Right Door Control Module >>> B2265 Horizontal Position Sensor Fault
Is this a sign that something is going bad?
Old Apr 1, 2012 | 02:37 AM
DeeGee's Avatar
DeeGee
U codes are normally power related, maybe a loose connection or battery problems. However, you'd expect to see more than one code. I'd clear the codes down and see if they come back.
With those codes you've had a minor power glitch at some time. As both codes are door related, if you're really feeling keen you could pull the rubber gaiters in the door hinges, check the wiring condition and clean and reseat the connectors.
At this stage, nothing to worry about.
DTC B2262-B2265
Circuit Description
The driver door module (DDM) and the passenger door module (PDM) receive mirror position signals from the mirror horizontal and vertical position sensors. These signals are used by the door modules for memory recall functions of the driver and passenger mirrors. The door modules command the mirror memory settings based upon the voltage level received back from the position sensors. Each door module provides a 5 volt supply, a signal and a ground circuit for each of the position sensors. The horizontal and vertical position sensors are variable resistors that the door modules monitor voltage levels across. When a memory setting is recalled, the door modules command the mirror motors in the appropriate directions until the stored position sensor voltage levels are achieved. The DDM and PDM monitor the signal circuits to determine if the voltage level is out of range. If the DDM or PDM detects a voltage level out of range for greater than 2 seconds, a DTC is set.
Old Apr 1, 2012 | 01:20 PM
El original's Avatar
El original
lol. How the heck do you know all this..work for GM at one time? Greetings, Rob
Old Apr 1, 2012 | 02:44 PM
DeeGee's Avatar
DeeGee
Who Me? I flew aeroplanes,
I just spent too much time on the Corvette Forum and bought a Shop Manual.
Old Apr 1, 2012 | 02:46 PM
darkstar.c5
DTC B2262-B2265
Circuit Description
Thats what makes this forum great! Thank you!
Old Apr 1, 2012 | 03:01 PM
DeeGee's Avatar
DeeGee
No trouble at all
To throwin codes
