harmonic balancer install
Old Apr 3, 2012 | 09:14 PM
firebird2002's Avatar
firebird2002
Default harmonic balancer install
does any one have link or a good how to on install on 02 vette ny help would be great thanks
Old Apr 3, 2012 | 09:20 PM
Paul 75 L82's Avatar
Paul 75 L82
There's a lot of info on this forum, I'm also a member of LS1Tech forum. There's also good info their. You might check out LS1HowTo.
Old Apr 3, 2012 | 10:25 PM
Qwik01's Avatar
Qwik01
http://www.digitalcorvettes.com/foru...d.php?t=104308
Have fun!
Old Apr 4, 2012 | 12:59 AM
onspeed's Avatar
onspeed
I need to do this soon as well.
Engine is under warranty but I'm not sure how comfortable I feel letting a dealer do this...
When switching to an underdrive pulley, is it still necessary to match the weights and etc?
Old Apr 4, 2012 | 01:16 AM
cor28vettes's Avatar
cor28vettes
You can also advance search
"harmonic install"
in C5 Tech
Tons of threads pop up including UD install
Old Apr 4, 2012 | 01:53 PM
98Redbird's Avatar
98Redbird
Just did mine yesterday and I read a lot before I did it. It depends on the bolt you're using. Stock GM or ARP?
I used an SLP/Powerbond pulley and new crank bolt from GM.
Install pulley with an appropriate installer. Or use the oven. I used the oven, heated to 225 degrees, and it slipped right on.
Then use the OLD bolt and torque to 240 lb ft. I torqued to 250 on accident, but oh well.
Then remove the bold and check the measurement of how far the crank snout is recessed in from the balancer face. Stock spec is .097-.176 I believe.
If you're good there, then take the new bolt, heat it up with a heat gun or hair dryer, apply red loc tite to the bottom 1/2 of the threads, install and torque to 37 lb ft.
Then rotate bolt and additional 140 degrees.
That's it.
Now that's for a GM bolt, if you're using an ARP then you just torque to a lb ft measurement and that's it.
Old Apr 4, 2012 | 02:07 PM
Scooter70's Avatar
Scooter70
Do yourself a favor and bake it in the oven. It will make the installation a snap.
Old Apr 4, 2012 | 02:46 PM
Paul Wood's Avatar
Paul Wood
A word of caution. Unless you are a seasoned DIY and have good mechanical skills, AND a good Service Manual, I would suggest you spend the money and have a good reputable shop replace this for you. There are some tricks, required special tools and some technical knowledge that make this seemingly simple job a nightmare. I do not know your ability so this is just a friendly, fellow forum member caution! Good Luck.
ps. While you in there I would replace the seal inside the timing chain cover and maybe even the cam, timing chain, if you have the funds or the inclination!
Old Apr 4, 2012 | 06:31 PM
bearphoto's Avatar
bearphoto
SoCal Events Coordinator
St. Jude Donor '12
This is a BIG job, do not attempt it unless you are an experienced auto mechanic!
Old Apr 4, 2012 | 06:42 PM
Fixed's Avatar
Fixed
I just did mine. I had to remove the stearing gear (rack), which took removing the abs pump bracket on my 2000. The lines that hook up to the stearing gear are a little tricky to remove, and put back in. The rack slid out through the drivers side. It helped big time to remove the radiator fans as well. It took a 3/4in impact to get the stock bolt out, and I replaced it with a ARP bolt. It also required a puller, and a pusher for install. While I was down that far, I replaced the timing cover gasket. I only had 40k miles, so I didn't do a timing chain. Don't go back with a factory balance. I used a Powerbond.
To harmonic balancer install
