Electrical Gremlins
Old Apr 4, 2012 | 08:19 AM
kpmunt's Avatar
kpmunt
Default Electrical Gremlins
Does anyone have a wiring diagram for the lighting system?
On my 02 I have the following problems:
1) Headlights won't retract
2) No taillights---blinkers work though
3) No dash lights.
Where to start searching?
Old Apr 4, 2012 | 08:32 AM
CactusCat's Avatar
CactusCat
3) No dash lights.
This would be a good place to start. Good luck and keep us informed of how it's coming along. And finish your profile, its helpful.
http://forums.corvetteforum.com/c5-t...dont-work.html
Old Apr 4, 2012 | 09:29 AM
The above is a good post - and if all else fails, get in touch with forum member Bill Curlee - he knows a lot about the C5 electrical system and may be able to point you in the right direction if you explain what is going on and what you have done so far to fix the problem. Good luck - electrical issues can be a real PITA.
Old Apr 4, 2012 | 10:12 PM
kpmunt's Avatar
kpmunt
Hey guys thanks for the response. All symptoms pointed to this as the problem. However, tonight I took the switch apart to do the fix. Didn't resolve anything. Maybe still a bad switch, IDK.
To Electrical Gremlins
