116 octane gas
Old Apr 5, 2012 | 12:55 AM
Green_Devil's Avatar
Green_Devil
Default 116 octane gas
Who uses 116 octane gas and can it cause damage?
Old Apr 5, 2012 | 02:49 AM
Jistari's Avatar
Jistari
Nope and yes it may.
You're tuned for 93, higher wont add any power. I would imagine you could tune for 116 (no idea on that) but the way your engine is built (if its stock) it will compress and fire 93 octane most efficiently, higher octane wont add any power.
http://www.corvetteactioncenter.com/tech/gas/gas2.html
Page 2
Old Apr 5, 2012 | 03:10 AM
Green_Devil
Page 2
Thanks for the info
Old Apr 5, 2012 | 07:55 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
I imagine you are referring to either C16 or Q16.. You cant run either one on a stock engine without damaging 02 sensors as well as cats. What is done to the engine now that made you think about running such a fuel?
Old Apr 5, 2012 | 08:40 AM
Good question - don't know why a stock engine would need anywhere near that octane level. Plus, why pay for something that really won't help you out.
Old Apr 5, 2012 | 09:15 AM
dougbfresh's Avatar
dougbfresh
It's usually people that don't know much about gasoline or ANYTHING about octane ratings.
Old Apr 5, 2012 | 09:20 AM
Cruise-In V Veteran
A stock engine is fine on 91-93 octane. Running too much octane will actually lose power.
Old Apr 5, 2012 | 04:58 PM
tiojames's Avatar
tiojames
If you were running hi-compression(12-15 to 1) and car was tuned for it it could be a benefit. On our engines it is not going to do much on the positive side.
Old Apr 5, 2012 | 06:18 PM
baxsom's Avatar
baxsom
the higher the octane the less energy is actually in each gallon. octane is just for anti knock. your power comes from being able to advance the timing without engine knock
Old Apr 5, 2012 | 11:08 PM
Jistari's Avatar
Jistari
Thats a very good analogy
And OP you're welcome, if you dont ask you'll never know (plus, thats what we do here, we have nothing else to do atm so we log in and give answers (not necessarily correct answers , those we charge for).
Old Apr 6, 2012 | 12:39 AM
itzza427's Avatar
itzza427
Wasn't 100% certain,BUT was pretty sure that about the highest you could get in UNLEADED was 100 octane,,and that the op's numbers had to be leaded. For stock , about toe only real use even for 100 would be to mix a few gallons to a tank if all you had available was 91. Might be my imagination but seems to do a tinny bit better on 93,,so you might blend your own!
To 116 octane gas
