how do i remove my targa top when im alone?
Old Apr 6, 2012 | 10:54 AM
andynpz's Avatar
andynpz
Default two hints
1. Open the driver's door and put left foot on the floor - will get you closer to the roof..............remember to lift your foot as you step back!!!!
2. Keep one or other of the rear locating pegs engaged until you have a good grip on the roof and are ready to lift
Old Apr 6, 2012 | 10:56 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
never had a problem...
Old Apr 6, 2012 | 10:59 AM
Mecinoid's Avatar
Mecinoid
My Process for removing the top and storing it is the hatch area:
Read instructions completely before attempting to take targa top off.
1. Pop rear hatch, make sure locking pins for top are retracted and leave the hatch open.
2. Put on gloves as needed that you previously stored in rear hatch compartment.
3. Roll down both windows and open driver door.
4. Unlock or Pop latches on top.
5. Standing on driverside of car, take right hand and push up underneath the front of the top. Use left hand to support front of the top out of the frame. While holding the front of the top with the rear pins still engaged use your right hand from underneath to guide the top forward and off rear pins. Lift the top off flat. Step back carrying away from the car with your top in your arms.
6. At this point you can easily lower top and get your right hand on rear edge of top. Swing front of top counterclockwise to your belly. Approach your opened hatch and lower the rear of top (or the part your holding with your right hand) into the pin blocks in the hatch area. They should slide right in place. Lower the front of the hatch with your left hand into its cradle position and use the locking pin arms to hold the top in place. Sometimes you have to wiggle the top a little to align the pins with the holes in the top.
7. Done - close hatch and enjoy your ride!
Installing can be a little tricky for the first few times if the top hasn't been off much. It's difficult to locate the rear top pins sometimes until broken in. Have someone help you reinstall the top if you top hasn't been off very much until your more comfortable with locating those pins. I was able to do this by myself until broken in but, I had to be real careful and it took a couple of minute to align it at times.
Now, it just slides right in the first time. My top has been off-on about 20-25 times. I do not believe the original owner every took the top off.
Old Apr 6, 2012 | 02:01 PM
Vette Gator 01's Avatar
Vette Gator 01
Default The easy way
I like to wait untill nobody is behind me on the inerstate accelerate to about 90 MPH, then release the latches. If it doesn't come off automajically then I give it a bump it's clear and free...
Old Apr 6, 2012 | 04:38 PM
jol's Avatar
jol
Make sure the wipers are off and you have fresh Mobil 1 in the car. Then follow the steps above.
Old Apr 6, 2012 | 04:50 PM
damilleniumboy's Avatar
damilleniumboy
Old Apr 6, 2012 | 09:40 PM
minitech's Avatar
minitech
How would you do it WITH help?
Old Apr 6, 2012 | 10:15 PM
VetteCop29's Avatar
VetteCop29
Originally Posted by corpsedub
i pop the hatch
sit in the car and pop all latches
then stand up while holding the roof.
then exit the car and put it in the trunk.
What he said ^
Old Apr 6, 2012 | 10:32 PM
theheartbeat's Avatar
theheartbeat
Originally Posted by TwinTurboZ51
Are you serious??
Unlatch it and take it off. Why would you need help unless you were an amputee?
Dude im blind... i cant drive i just sit im my car to look cool like you.
Old Apr 6, 2012 | 10:35 PM
Major Dump's Avatar
Major Dump
I thought it was easy to take off by your self, lots of people do it. Unlatch the top and then stand on the gas. It'll remove it self.
Old Apr 6, 2012 | 11:04 PM
theheartbeat
thats original........even after the 3rd time on this thread alone.
Old Apr 6, 2012 | 11:18 PM
damilleniumboy
This is how I do it =]
Old Apr 6, 2012 | 11:27 PM
  #33
jrprich's Avatar
jrprich
I always remove mine alone and never with gloves on.
Old Apr 7, 2012 | 12:25 AM
  #34
CBZZZC5's Avatar
CBZZZC5
Originally Posted by theheartbeat
can it be done..
really !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!
Old Apr 7, 2012 | 12:46 AM
  #35
o2bnkc's Avatar
o2bnkc
Are you serious??
Old Apr 7, 2012 | 07:16 AM
  #36
Silverback51's Avatar
Silverback51
You're not the same guy that asked how to keep his car clean when driven in the rain are you?
Old Apr 7, 2012 | 09:09 AM
  #37
ALLEGRO's Avatar
ALLEGRO
To how do i remove my targa top when im alone?
Old Apr 7, 2012 | 06:56 PM
  #38
theheartbeat
without watching this "let me guess they unlatch the top while driving?"
once again after the 4th time on this thread alone, this is still not to funny
Old Apr 7, 2012 | 06:57 PM
  #39
theheartbeat
your not the same guy that asked if black wheels look good on a c5 are you?
Old Apr 7, 2012 | 07:08 PM
  #40
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
