[Z06] X pipe replacement on stock 2002 C5 Z06
1 Post
I have figured out that I have a loose piece of metal in my X pipe and it's getting decently annoying. So I want to replace it, but I'd rather do a somewhat upgrade while doing so.
I found this, however, it seems like it doesn't come with the FULL Xpipe. I want an Xpipe that comes with piping from the bottom of the exhaust manifold to the axle-back.
http://www.westcoastcorvette.com/p-2...04-c5-z06.aspx
I want to replace this entire assembly with high flow cats that will retain a decent stock sound vehicle. I want to get by with saying I have stock exhaust if I want to. Here is a picture of the assembly I wish to replace. I'd also like there to be an extra bung on it for a wideband.
I am spraying the car, so I've heard I will clog up the stock flowing cats pretty good and want to avoid that. Not interesting in upgrading the exhaust manifolds or axleback. Just want the x-pipe tailor made to my likings. Anyone on here have any suggestions or links to FULL Xpipes I could consider?
Thanks in advance,
-Hippo
Thanks in advance,
-Hippo
I have only seen complete bolt on X pipes for headers. the other X-pipes are designed to replace after the cats so you would need to cut the stock H-pipe and clamp/weld this on to the stock cats. Im supprised i have not found a full bolt on kit from flange to flange as well.... any venders make something like this? I would think there would be a few out there that could be bolted on in someones driveway in a couple hours.... I would also be interested in one Flange to flange for stock manifolds/mufflers with Magnaflow cats... Altho i hear the stock cats flow pretty well already so i wouldnt be affraid to take it in and have it welded up to stock cats (which looks like the only option without headers.
S
S
Magnaflow sells the whole setup...it comes in 2 pieces though. The front half will have the high flow cats that bolt up to the manifolds and then the back section is the x-pipe that will bolt up to the mufflers.
I had a Bassani "slip fit" X-pipe installed on my Z at Mid America. I dont really remember any cutting involved but the install looked easy even though the Z was on a lift. I would look into the Bassani. With the stock titanium exhaust, it has a deeper,throatier sound, but not obnoxious. Sounds a lot more agressive a WOT.
1 Post
Good info, thank you!
I'm actually looking into the LS7/LS9 Exhaust Manifold/H-pipe(X-pipe for LS9) swap. People seem to have great gains from it too.
I can get the whole system (Exhaust manifolds, downpipes, Hpipe or X pipe) for $425 shipped. Debating on whether that is worth the $$ or maybe just wait and get the XSPower Longtubes/Xpipe.
Thanks again!
-Hippo
Thanks again!
-Hippo
Thanks again!
-Hippo
Thanks again!
-Hippo
